Enable HTTPS on the WebLogic Server To encrypt the communication between BIP and SDM, first enable HTTPS on the WebLogic server. Login to the administrative console of your WebLogic server. Use the username and password you created when installing BI Publisher. In the default installation, the administrative console can be reached at http://<IP address>:7001/console. Under Domain Structure section of the pane in the left panel, click to expand the Environment menu and click Servers. In the main tab of the Summary of Servers section of the pane, check the AdminServer(admin) check box. In the Change Center section of the pane, click Lock & Edit. In the Configuration tab, General sub-tab, click the SSL Listen Port Enabled check box and enter the port number in the SSL Listen Port field. Click Save. In the Change Center of the pane, click Activate Changes. In a cluster setup, repeat this task for each BIP server.
