Scheduling Reports in BI Publisher After a report is created, you may schedule the report to run at regular intervals. To schedule reports: If you have already created the report, from the Home tab click More > Schedule under the report you want to schedule. If you are in the process of creating a job, click on the Schedule tab. Select the frequency from the drop-down list. Select the start time and, if given, the stop time. If you want to conditionally execute reports, select the Use Trigger check box and specify the relevant data model. Enter a name for the report and click OK. Click Submit.
