Scheduled Reports
To create a canned report in BI Publisher:
From the Report Manager slider, click
Operational Reports.
This will sign you in to BI Publisher.
Click on Report Job in the Create section of the Home tab.
Click on the magnifying glass icon to select a report.
- Expand Shared Folders > OCSRM > Reports.
Select the canned report you want. Then select the time granularity you want.
- Click Open.
Select the Start Time and End Time.
- Click Submit in the top right corner.
