PreviousNextJavaScript must be enabled to correctly display this content
Add a New Route Set
A route set is a container of routes and information about these routes such as their public identifier (PUB ID) and other information, such as the number of hops for a route and so on. Route sets are used to update LRT data on device groups that use an LRT file.
Expand the
Route Manager slider, and click
Route sets.
In the
Route sets tab, click
Add.
In the
Add Route Set dialog box, complete the following fields:
Name
Description
Route Set Type field
The
SBC radio button is selected by default for the Session Border Controller (SBC) route set type. The DSC option is deprecated.
Name field
The name for the new route set using alphanumeric characters without spaces.
Device LRT configuration name field
The configuration name of the local route table (LRT) associated with the route set. This value must match the configured name on the device.
Device LRT file name field
The name used for this LRT file, which must match the LRT file name in the device configuration and select its extension. The default file extension is
.xml.gz.
pub-id type drop-down list
(Required) Select the public identifier in the form of a telephone number or prefix (for example, NPA-NXX) used in LRT lookup for this route set.
Description field
(Optional) Enter a description for this route set.
Notes field
(Optional) Enter a note for this route set.
Populate from existing route set drop-down list
(Optional) Use the parameters of a pre-existing route set.
