Copying Route Sets
You can copy an existing route set to make a new route set.
- Expand the Route Manager slider, and click Route sets.
In the
Route sets tab, select the route set and click
Lock.
The lock state toggles from unlocked, indicated by
, to locked, indicated by
. The name of the user who locked the route set is listed.
- With the locked route set selected, click Copy.
In the
Copy Route Set dialog box, complete the following fields:
Name Description Name field The name for the route set copy using alphanumeric characters without spaces. Device LRT configuration name field The configuration name of the local route table (LRT) associated with the route set. This value must match the configured name on the device. Device LRT file name field The name used for this LRT file, which must match the LRT file name in the device configuration and select its extension. The default file extension is .xml.gz. Description field (Optional) Enter a description for this route set. Notes field (Optional) Enter a note for this route set. Populate from existing route set drop-down list (Optional) Use the parameters of the existing route set from which you want to populate or the name of the route set you want to copy. - Click OK.
