Viewing LRT Files
- Expand the Route Manager slider, and click Route sets.
In the
Route sets tab, select the route set row in the table and click
View LRT File.
A status message shows the progress of loading the LRT file. After the file is loaded, you are prompted to either open or save the file.
- Open the file in an XML editor to review or modify this file, or save the file.
