File Selection
- Expand the Route Manager slider, and click Route sets.
In the
Route sets tab, select the route set you want to manage and click
Lock.
The lock state toggles from unlocked, indicated by
, to locked, indicated by
. The name of the user who locked the route set is listed.
- With the locked route set selected, click Manage Routes.
- In the Route Set Edit tab, click Import.
In the
Route Set Import - Step 1 -File Selection pane, complete the following fields:
Name Description File field The CSV file path. You can click Browse to find the CSV file that you want to import from your system. Does the file contain a header line field Select the Yes or No radio button depending on whether your CSV file has a header line or not. File delimiter drop-down list Select from the following file delimiting method: - Comma
- Tab
- Space
Template to use drop-down list Select an available template, or leave this field blank. See the Manage Import Templates section for more information. - Click Next.
Continue to the next section (Route Set Import -Step 2 - CSV Column Assignments pane).
