PreviousNextJavaScript must be enabled to correctly display this content
Comparing Route Sets
Use this task when comparing the contents of a route set with the route set contained in the LRT file of an active device before updating the contents of the route set.
Expand the
Route Manager slider, and click
Route sets.
Select the
Route Set Compare tab, and complete the following fields:
Name
Description
Route Set Type field
The
SBC radio button is selected by default for the Session Border Controller (SBC) route set type. The DSC option is deprecated.
Route Set 1 drop-down list
Select the first route set.
Route Set 2 drop-down list
Select the second route set. The
Compare button is activated.
Click
Compare.
A progress bar appears while the comparison is processed. When complete, the results are displayed in two columns at the bottom of the screen. If the contents are identical between the two, messages appear in both columns.
