snmp-user-entry
The snmp-user-entry element is used to create SNMP users for use with SNMPv3.
Parameters
- user-name
- Enter the name of the user authorized for retrieving SNMPv3 information.
- auth-password
- Enter the authorization password for this user. This value will be obscured when displayed at the ACLI.
- priv-password
- Enter the privacy password for this user. This value will be obscured when displayed at the ACLI.
Path
snmp-community is an element under the system path. The full path from the topmost ACLI prompt is:
This is a multiple instance configuration element.
