snmp-community
The snmp-community element defines the NMSs from which the Oracle Communications Session Border Controller will accept SNMP requests.
Parameters
- community-name
- Enter the name of the SNMP community to which a particular NMS belongs. This required entry must follow the Name Format. The community-name field values must be unique.
- access-mode
- Select the access level for each snmp-community element
- Default: READ-ONLY
- Values:
- READ-ONLY—Allows GET requests
- READ-WRITE—Unsupported
- ip-addresses
- Enter the IP address(es) for SNMP communities for authentication purposes. Entries must follow the IP Address Format. This parameter can accept IPv4, IPv6, or a combination of the two.
Path
The full path from the topmost ACLI prompt is:
This is a multiple instance configuration element.
