setup product
The setup product command is used to assign a product type to this instance of software and hardware combination. By executing this command, you will be faced with a list of valid products you may provision this system as. Choose the appropriate product and hit the <Enter> key to accept.
Syntax
setup product
Mode
Superuser
ORACLE# setup product
WARNING:
Alteration of product alone or in conjunction with entitlement
changes will not be complete until system reboot
Last Modified
1 : Product : Uninitialized
Enter 1 to modify, d' to display, 's' to save, 'q' to exit. [s]: 1
Product
1 - Session Border Controller
2 - Session Router - Session Stateful
3 - Session Router - Transaction Stateful
4 - Peering Session Border Controller
Enter choice : 1
Enter 1 to modify, d' to display, 's' to save, 'q' to exit. [s]: s
save SUCCESS
