setup entitlements
The setup entitlements command is used to self configure entitlements for the product you chose in the setup product command. By executing this command, you will be faced with a list of valid entitlements for the product-platform-software combination you are currently running. You can select entitlements to enable or provision capacity based entitlements from this command.
Syntax
setup entitlements
Mode
Superuser
ORACLE# setup entitlements
Entitlements for Session Border Controller
Last Modified: 2014-06-01 18:57:55
1 : Session Capacity : 32000
2 : Accounting : enabled
3 : IPv4 - IPv6 Interworking :
4 : IWF (SIP-H323) : enabled
5 : Load Balancing : enabled
6 : Policy Server : enabled
7 : Quality of Service : enabled
8 : Routing : enabled
9 : SIPREC Session Recording : enabled
10: Admin Security with ACP/NNC :
11: IMS-AKA Endpoints : 0
12: IPSec Trunking Sessions : 0
13: MSRP B2BUA Sessions : 0
14: SRTP Sessions : 0
Enter 1 - 14 to modify, d' to display, 's' to save, 'q' to exit. [s]: s
SAVE SUCCEEDED
