This chapter includes the keystroke reference details for the following Administration related modules:
Figure 3: OFSDF Administration Page
This section includes the keystroke reference details for the following menus in the System Configuration Module:
· Configure Application Server
· Configure System Configuration
The following table describes all the elements of the System Configuration – Configure Database Server Section and the keystroke combinations to access them.
UI Control |
How Does the UI Control Look |
List of UI Controls on the Screen |
Keystrokes to Access This UI Control |
html5-select-one
IP Address |
html5-textbox
· Socket Server Port · OS type · Drive · Port Number · User ID · Password |
html5-radiobutton
· FTP · SFTP · LOCAL |
html5-tab
· Technical Metadata · Business Metadata · Staging Area |
html5-button |
Modify
html5-button |
Next
html5-button |
Cancel
html5-button |
Help icon |
The following table describes all the elements of the System Configuration – Configure Application Server Section and the keystroke combinations to access them.
UI Control |
html5-textbox
· Primary IP For Runtime Processes · Drive · Port Number · User ID · Password |
html5-radiobutton
html5-select-one
Authentication Type |
html5-tab
html5-button |
· Modify · Cancel · Help icon |
The following table describes all the elements of the System Configuration – Configure Web Server Section and the keystroke combinations to access them.
UI Control |
html5-select-one
· IP Address · Protocol |
html5-textbox
· Servlet Port · Local Path |
html5-checkbox
· Transfer Protocol Details |
html5-button |
Modify
html5-button |
Cancel
html5-button |
Help icon |
The following table describes all the elements of the System Configuration – OLAP Details Section and the keystroke combinations to access them.
UI Control |
html5-select-one
· Server IP · Type · Locale Identifier |
html5-textbox
· User ID · Password · FIV User ID · FIV Password |
html5-button |
Add
html5-button |
Save
html5-button |
Cancel
html5-button |
Help button |
The following table describes all the elements of the System Configuration – Configure System Configuration Section and the keystroke combinations to access them.
UI Control |
html5-select-one
· Authentication Type · Hierarchy Security Type · Guest Login · Guest Password |
html5-textbox
· Number of invalid logins · Path for Application Packaging · Session Timeout Value(in minute) · Session Timeout Popup Interval(in minutes) · Environment Details · Dormant Days · Inactive Days · Working Hours From and To · Frequency of Password Change · Password History · Password Length Minimum and Maximum · Numbers Minimum and Maximum · Upper Case Minimum and Maximum · Lower Case Minimum and Maximum · Special Character Minimum and Maximum · Special Character Occurrence Frequency · Disallowed Special Characters · Input File Format · Output File Format · Encryption Key Path · Link based token validity in minutes · API token validity in seconds · Guest Password · Limit on number of mappings displayed · Page size used in tree pagination |
html5-tab
· General Details · Guest Login · Optimization · Others |
html5-button |
Save
html5-button |
Cancel
html5-button |
Help icon |
html5-checkbox
· SSO Enabled · Enable native authentication for Rest API · Allow user to log in from multiple machines · Allow Data Redaction · Encrypt Login Password · Enable CSRF Protection · Special Characters Allowed · Running Alphabets · Running Numbers · Enable Batch Operation Notification · Enable Batch Owner Notification Only · CMIS Enabled · Security Question Enable · Use ROWID in ON clause of MERGE statement · Application uses new Run Rule Framework · Enable audit log through Security Management System · Populate Execution Statistics · Allow Correction on DI Source |
html5-textrea
Disclaimer text |
html5-radiobutton
Password Restriction |
This section includes the keystroke reference details for the Identity Management Module. It includes the following screens:
Figure 4: Identity Management
This section includes the keystroke reference details for the menu in the Security Management Module.
This section includes the keystroke reference details for the User Administrator Menu.
The following table describes all the elements of the User Maintenance Section and the keystroke combinations to access them.
UI Control |
html5-textbox
· User ID · Name · Profile Name |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
html5-button |
Delete |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-pagination |
· Page · Records Per Page |
html5-grid |
User Maintenance |
html5-checkbox
User ID |
The following table describes all the elements of the User Definition (add/view/edit) section and the keystroke combinations to access them.
UI Control |
html5-select-one
· Profile Name · Database authentication principal |
html5-textbox
· Employee Code · Address · Designation · Password · Start · End · Mobile Number · Email ID · Pager Number |
html5-calendar |
· Date of Birth · Start Date · End Date |
html5-button |
Save |
html5-button |
Cancel |
html5-checkbox
· Enable User · Login on Holidays · Proxy User name · Enable Proxy |
The following table describes all the elements of the Identity Management - User Group Maintenance section and the keystroke combinations to access them.
UI Control |
html5-textbox
· User Group ID · Group Name · Description |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
html5-button |
Delete |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-pagination |
html5-grid |
User Maintenance |
html5-checkbox
User Group ID |
The following table describes all the elements of the User Group Definition (add/view/edit) section and the keystroke combinations to access them.
UI Control |
html5-textbox
· User Group ID · Group Name · Description · Precedence |
html5-button |
· Save · Cancel |
html5-button |
Save |
The following table describes all the elements of the User Group Map Section and the keystroke combinations to access them.
UI Control |
html5-textbox
· User ID · Name |
html5-button |
· Help · Search · Reset |
html5-button |
Search |
html5-button |
Reset |
html5-records-per-page |
Records Per Page |
html5-grid |
User – User Group Map |
html5-checkbox
User ID |
The following table describes all the elements of the Security Management – User Administrator –Profile Maintenance Section and the keystroke combinations to access them.
UI Control |
html5-textbox
· Profile Code · Profile Name |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
html5-button |
Delete |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
Records Per Page |
html5-grid |
Profile Maintenance Grid |
html5-checkbox
Profile Code |
The following table describes all the elements of the Profile Definition (add/view/edit) Section and the keystroke combinations to access them.
UI Control |
html5-select-one
· Time Zone · Holiday Time Zone |
html5-textbox
html5-button |
Save |
html5-button |
Cancel |
html5-checkbox
· Sunday · Monday · Tuesday · Wednesday · Thursday · Friday · Saturday |
The following table describes all the elements of the User Authorization Section and the keystroke combinations to access them.
UI Control |
html5-textbox
· User ID · Name |
html5-radiobutton
User ID |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-button |
Authorize |
html5-button |
Reject |
html5-grid |
User Authorization Grid |
The following table describes all the elements of the User Group Authorization Section and the keystroke combinations to access them.
UI Control |
html5-textbox
· Group Code · Group Name |
html5-radiobutton
· Group Name · Business Administrator |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-grid |
Group Name Grid |
Records Per Page |
The following table describes all the elements of the Authorization for User Group Folder Mapping Section and the keystroke combinations to access them.
UI Control |
html5-textbox
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
Records Per Page |
The following table describes all the elements of the User Group Domain Map Section and the keystroke combinations to access them.
UI Control |
html5-textbox
html5-button |
· Search · Reset · Help |
Records Per Page |
html5-grid |
User Group Domain Name grid |
html5-checkbox
User Group ID |
The following table describes all the elements of the User Group Role Map Section and the keystroke combinations to access them.
UI Control |
html5-textbox
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
Records Per Page |
html5-grid |
User Group Role Map grid |
html5-checkbox
User Group ID |
The following table describes all the elements of the User Group Folder Role Map Section and the keystroke combinations to access them.
UI Control |
html5-textbox
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
Records Per Page |
html5-grid |
html5-checkbox
User Group ID |
The following table describes all the elements of the User Reinstate Section and the keystroke combinations to access them.
UI Control |
html5-textbox
· User ID · Name |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
Records Per Page |
html5-grid |
User Reinstate grid |
html5-checkbox
User ID |
This section includes the keystroke reference details for the System Administrator Menu.
The following table describes all the elements of the Function Maintenance Section and the keystroke combinations to access them.
UI Control |
html5-textbox
· Function Code · Function Name · Description |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
html5-button |
Delete |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-pagination |
html5-grid |
Function Maintenance grid |
html5-checkbox
Function Code |
The following table describes all the elements of the Function Definition (add) section and the keystroke combinations to access them.
UI Control |
html5-textbox
· Function Code · Function Name · Function Description |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
The following table describes all the elements of the Role Maintenance Section and the keystroke combinations to access them.
UI Control |
html5-textbox
· Role Code · Role Name · Role Description |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
html5-button |
Delete |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-pagination |
html5-grid |
Role Maintenance grid |
html5-checkbox
Role Code Select Checkbox |
The following table describes all the elements of the Role Definition (add/view/edit) Section and the keystroke combinations to access them.
UI Control |
html5-textbox
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
The following table describes all the elements of the Function Role Map Section and the keystroke combinations to access them.
UI Control |
html5-textbox
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-pagination |
html5-grid |
html5-checkbox
Role Code |
The following table describes all the elements of the Segment Maintenance Section and the keystroke combinations to access them.
UI Control |
html5-select-one
· Segment/Folder Type · Owner Code |
html5-textbox
· Domain · Segment Code · Segment Name · Segment Description |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
html5-button |
Delete |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-pagination |
html5-grid |
Segment Maintenance grid |
html5-checkbox
Domain |
The following table describes all the elements of the Segment Definition (add/view/edit) section and the keystroke combinations to access them.
UI Control |
html5-select-one
· Domain · Segment/Folder Type · Owner Code |
html5-textbox
· Segment Name · Segment Code · Segment Description |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
The following table describes all the elements of the Holiday Maintenance Section and the keystroke combinations to access them.
UI Control |
html5-button |
Add |
html5-button |
Delete |
html5-button |
Help |
html5-grid |
Holiday List grid |
html5-checkbox
Holiday List checkbox |
html5-calendar
New- Holiday |
html5-button |
Save |
html5-button |
Cancel |
The following table describes all the elements of the Identity Management - Restricted Passwords Section and the keystroke combinations to access them.
UI Control |
html5-textbox
Password List |
html5-button |
Add |
html5-button |
Delete |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
The following table describes all the elements of the Restricted Passwords (add/view/edit) Section and the keystroke combinations to access them.
UI Control |
html5-textbox
Password List |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
This section includes the keystroke reference details for the User Activity Report Menu.
The following table describes all the elements of the Currently Logged in Users Section and the keystroke combinations to access them.
UI Control |
html5-button |
Help |
html5-button |
Save |
html5-grid |
Currently logged in Users grid |
The following table describes all the elements of the Security Management – User Activity Report – Disabled Users Section and the keystroke combinations to access them.
UI Control |
html5-button |
Help |
html5-button |
Save |
html5-grid |
Disabled Users grid |
The following table describes all the elements of the Deleted Users Section and the keystroke combinations to access them.
UI Control |
html5-button |
Help |
html5-button |
Save |
html5-grid |
Deleted Users grid |
The following table describes all the elements of the Unauthorized Users Section and the keystroke combinations to access them.
UI Control |
html5-button |
Help · |
html5-button |
Save |
html5-grid |
Unauthorized Users grid |
The following table describes all the elements of the Idle Users section and the keystroke combinations to access them.
UI Control |
html5-button |
Save |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-grid |
Idle Users grid |
The following table describes all the elements of the Role Master Report Section and the keystroke combinations to access them.
UI Control |
html5-button |
Export to Excel |
html5-button |
Export to PDF |
html5-grid |
Role Master Report grid |
The following table describes all the elements of the User ID Population Report Section and the keystroke combinations to access them.
UI Control |
html5-textbox
User ID |
html5-button |
Export to Excel |
The following table describes all the elements of the UAM Admin Activity Report Section and the keystroke combinations to access them.
UI Control |
html5-textbox
User ID |
html5-calendar |
html5-button |
Export to Excel |
html5-button |
Export to PDF |
html5-button |
Search |
This section includes the keystroke reference details for the User Profile Report Menu.
The following table describes all the elements of User Profile Report Section and the keystroke combinations to access them.
UI Control |
html5-radiobutton
· File · Screen |
html5-button |
Map |
html5-button |
Generate Reports
html5-button |
Help |
html5-button |
Reset |
html5-grid |
User Profile Grid |
UI Control |
html5-textbox
Search |
html5-map-matadata-hierarchy-shuttle
Map Metadata Hierarchy Shuttle |
The following table describes all the elements of the Enable User Section and the keystroke combinations to access them.
UI Control |
html5-select-one
User ID |
html5-button |
Search |
html5-button |
Reset |
html5-button |
Save |
html5-checkbox
· Enable Login · Clear Station |
This section includes the keystroke reference details for the Database Details Module.
Topics:
· Summary
· Details
Figure 5: Database Details Module
The following table describes all the elements of the Summary Section (Database Master Page with Database Details for DB Server Section) and the keystroke combinations to access them.
UI Control |
html5-radiobutton
Select |
html5-button |
Help |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
html5-grid |
Database Details for DB Server |
html5-checkbox
Checkbox to select the record |
The following table lists all the elements of the Database Master Details Page for Add, View, and Edit operations, and the associated keystroke combinations to access them.
UI Control |
html5-select-one
· DB Server · DB Type · Auth Type · Alias Name |
html5-textbox
· Name · Schema Name · Auth Type · Date Format · JDBC Connection String · JDBC Driver · Created By · Last Modified By · Creation Date · Last Modification Date |
html5-grid |
DB Details |
html5-button |
Help |
html5-button |
Save |
html5-button |
Cancel |
html5-button |
OK |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
The following table lists all the elements of the Alias Details Page and the associated keystroke combinations to access them.
UI Control |
html5-textbox
· Auth Alias · User/Principal Name · Auth String |
html5-button |
Save |
html5-button |
Cancel |
The following table describes all the elements of the Manage OFSAA Application Pack Licenses Section and the keystroke combinations to access them.
UI Control |
html5-radiobutton
Application Pack ID |
html5-grid |
Installed Application Packs Grid |
This section includes the keystroke reference details for the Create New Application Module.
Topics:
· Summary
· Details
The following table describes all the elements of the Create New Application Summary Screen and the keystroke combinations to access them.
UI Control |
html5-select-one
Information Domain |
html5-textbox
· Application ID · Application Pack Name · Application Name |
html5-button |
Search |
html5-button |
Reset
html5-button |
Help
html5-button |
Add
html5-button |
View
html5-button |
Edit |
html5-grid |
Applications grid |
html5-checkbox
· Enabled · Application ID |
The following table describes all the elements of the Create New Application Details Screen and the keystroke combinations to access them.
UI Control |
html5-select-one
html5-textbox
· Application ID · Application Description · Application Pack Name · Application Name |
html5-button |
Save |
html5-button |
Cancel |
html5-checkbox
Enabled |
This section includes the keystroke reference details for the Information Domain Module. It includes the following screens:
Topics:
· Information Domain – Summary
· Information Domain - Details
Figure 6: Information Domain Module
The following table describes all the elements of the Information Domain Screen and the keystroke combinations to access them.
UI Control |
html5-select-one
Name |
html5-textbox
Description |
html5-button |
Add |
html5-button |
Next |
html5-button |
Save |
html5-button |
Delete |
html5-button |
Cancel |
html5-button |
Help |
html5-checkbox
· Is authorization required for Business Metadata? · Is this a Staging Information Domain? |
The following table describes all the elements of the Information Domain - Details screen and the keystroke combinations to access them.
UI Control |
html5-textbox
· Name · Description · ERWIN File Path · Log File Path · Scripts File Path · Entity · Name · Pager · Mobile · Branch Manager Entity · Branch Manager Email · Relationship Manager Entity · Relationship Manager Email |
html5-select-one
· Database Server · Database Name · OLAP Server · OLAP Type · Meta Database Server · Meta Database Name |
html5-button |
Help |
html5-button |
Next |
html5-button |
Cancel |
html5-button |
Back |
html5-checkbox
This section includes the keystroke reference details for the Translation Tools Module. It includes the following screens:
Topics:
Figure 7: Config Schema Download Module
Figure 8: Config Schema Upload Module
The following table describes all the elements of the Config Schema Download Section and the keystroke combinations to access them.
UI Control |
html5-select-one
· Select the table · Format to download |
html5-button |
Download |
html5-textrea
Filter (Where clause) |
The following table describes all the elements of the Config Schema Upload Section and the keystroke combinations to access them.
UI Control |
html5-select-one
Select the table |
html5-button |
Upload |
html5-button |
View Log |
html5-textbox |
Source Date Format |
html5-filepicker |
Select the file to Upload |
html5-dialog-launcher |
Select the sheet |
This section includes the keystroke reference details for the Object Administration Module. This module includes the following screens:
· Object to Application Mapping
Figure 9: Object Administration Module
This section includes the keystroke reference details for the Metadata Segment Mapping Module.
The following table lists all the elements of the Object Administration - Metadata Segment Mapping Page and the associated keystroke combinations to access them.
UI Control |
html5-select-one |
· Information Domain · User Segment |
html5-radiobutton
· Measure · Hierarchy · Cube · Attribute · Map |
html5-button |
Help |
html5-button |
Save |
html5-button |
Show Details |
html5-button |
Hide Details |
This section includes the keystroke reference details for the Batch Execution Rights Module.
The following table lists all the elements of the Batch Execution Map Page and the associated keystroke combinations to access them.
UI Control |
html5-select-one
· Information Domain · User Groups |
html5-radiobutton
· Batch Maintenance · Enterprise Modeling · Run Rules Framework · ALL |
html5-button |
Help |
html5-button |
Check All |
html5-button |
Uncheck All |
html5-button |
Save |
html5-button |
Cancel |
html5-button |
Search |
html5-button |
Reset |
html5-button |
OK |
html5-grid |
User Group Batch Execution Map |
html5-checkbox
Batch Map |
The following table lists all the elements of the Batch Execution Rights– Search Page and the associated keystroke combinations to access them.
UI Control |
html5-textbox
Search for |
html5-button |
OK |
html5-button |
Cancel |
This section includes the keystroke reference details for the Object to Application Mapping Module. See Metadata Browser section for details.
This section includes the keystroke reference details for the Object Migration Module.
The following table describes all the elements of the Object Migration Summary Section and the keystroke combinations to access them.
UI Control |
html5-select-one
Folder |
html5-textbox
Name |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
html5-button |
Copy |
html5-button |
Delete |
html5-button |
Run |
html5-button |
Cancel Run |
html5-button |
Configuration |
html5-button |
View Configuration |
html5-button |
Refresh |
html5-button |
View Log |
html5-grid |
Object Migration |
html5-checkbox
html5-messages |
· Confirm · Information |
html5-pagination |
Page |
Records per Page |
The following table lists all the elements of the View Log Page with summary and the associated keystroke combinations to access them.
UI Control |
html5-button |
Help |
html5-button |
Search |
html5-button |
Reset |
html5-button |
Refresh |
html5-button |
Task ID |
html5-button |
Descending Sort |
html5-select-one
· Component Type · Folder |
html5-textbox
· User · Batch Run ID |
html5-calendar |
As of Date |
html5-grid |
· Task ID Information · Log Information |
Task Name Dialog Launcher |
html5-pagination |
Page |
Records per Page |
Records per Page |
The following table describes all the elements of the Source Configuration and View Configuration Sections, and the keystroke combinations to access them.
UI Control |
html5-button |
Help |
html5-button |
Validate |
html5-button |
Save |
html5-button |
Cancel |
html5-button |
Add |
html5-button |
Close |
html5-textbox
· Name · JDBC Driver Name · JDBC Connection String · User ID · Password · Web Server URL · Source Infodom · Created By · Creation Date · Last Modified By · Last Modification Date |
html5-select-one
Name |
html5-textarea
Description |
The elements in the Add, View, and Edit operations pages are mentioned in the following tables.
The following table describes all the elements of the Object Migration Details Section and the keystroke combinations to access them.
UI Control |
html5-navigation-tree |
Navigation Tree |
html5-select-one
· Folder · Source |
html5-textbox
Name |
html5-radiobutton
· Read Only · Read/Write |
html5-textarea
Description |
html5-checkbox
Overwrite Object |
html5-button |
Help |
html5-button |
Save |
html5-button |
Migrate |
html5-button |
Cancel |
The following table describes all the elements of the Object Selection and Placement Section and the keystroke combinations to access them.
UI Control |
html5-select-one
· Source Folder · Target Folder · Source Segment · Target Segment · Dimension
Records per Page |
html5-pagination |
Pagination |
html5-button |
Search |
html5-button |
Reset |
html5-tab
· Available Aliases · Selected Aliases · Existing Aliases · Available Data Quality Rule · Selected Data Quality Rule · Existing Data Quality Rule · Available Datasets · Selected Datasets · Existing Datasets · Available Business Measures · Selected Business Measures · Existing Business Measures · Available Data Quality Group · Selected Data Quality Group · Existing Data Quality Group · Available Business Hierarchies · Selected Business Hierarchies · Existing Business Hierarchies · Available Business Dimensions · Selected Business Dimensions · Existing Business Dimensions · Available Essbase Cubes · Selected Essbase Cubes · Existing Essbase Cubes · Available Business Processors · Selected Business Processors · Existing Business Processors · Available Dimensions · Selected Dimensions · Existing Dimensions · Available Hierarchies · Selected Hierarchies · Existing Hierarchies · Available Filters · Selected Filters · Existing Filters · Available Expressions · Selected Expressions · Existing Expressions · Available SQL Rules · Selected SQL Rules · Existing SQL Rules |
html5-hierarchy-browser-shuttle |
Hierarchy Browser Shuttle |
UI Control |
html5-textbox
· Name · Description |
html5-button |
Search |
html5-button |
Reset |
html5-button |
Cancel |
The following table describes all the elements of the Selected Objects Section, and the keystroke combinations to access them.
UI Control |
html5-grid |
Dimension |
Records per Page |
html5-button |
Refresh Properties |
html5-button |
Refresh Dependencies |
html5-button |
Add |
html5-button |
View |
html5-button |
Edit |
html5-button |
Delete |
The following table describes all the elements of the Selected Objects Section with Child and Parent Dependency Information and the keystroke combinations to access them.
UI Control |
html5-radiobutton
· Parent · Child |
Records per Page |
html5-pagination |
Pagination |
html5-grid |
Dependency Information |
html5-button |
Close |
The following table describes all the elements of the Dependent Objects Section and the keystroke combinations to access them.
UI Control |
html5-tab
· Audit Trail · User Comments |
html5-grid |
User Comments |
html5-checkbox
html5-pagination |
Page |
Records per Page |
html5-textbox
· Comments · Created By · Created Date · Last Modified by · Last Modification Date |
html5-button |
Save |
html5-button |
Cancel |
This section includes the keystroke reference details for the Export Objects Module.
The following table lists all the elements of the Export Objects Summary Page, and the associated keystroke combinations to access them.
UI Control |
oj-lux-Breadcrumbs |
Breadcrumbs |
oj-cca-summary-search |
Summary Search |
oj-input-text |
· Name · Description · Code · Type |
oj-select-single |
Sort By |
oj-button |
Add |
oj-button |
Search |
oj-button |
Cancel |
oj-cca-pagination |
Page |
oj-cca-records |
Records |
The following table lists all the elements of the Outline Definition, and the associated keystroke combinations to access them.
UI Control |
oj-dialog |
Outline Definition |
oj-radio |
· Outline · Snapshot |
oj-textbox |
· Outline Name · File Name · Snapshot Name |
oj-select-single |
Sort By |
oj-button |
Close |
oj-button |
Apply |
oj-button |
Close |
The following table lists all the elements of the Object Selection Page in the Export Objects, and the associated keystroke combinations to access them.
UI Control |
oj-lux-breadcrumbs |
Breadcrumbs |
Summary Search |
oj-select-single |
Object Types |
oj-switch |
All |
oj-list-view |
List View |
oj-checkbox |
Checkbox |
oj-accordion |
oj-button |
Expand/Collapse Outline |
oj-tree-view |
oj-button |
Details |
oj-button |
Save Snapshot |
oj-button |
Save |
oj-cca-pagination |
Page |
oj-cca-records |
Records |
The following table lists all the elements of the Show Dependency Page in the Export Objects, and the associated keystroke combinations to access them.
UI Control |
Breadcrumbs |
oj-button |
Save Snapshot |
oj-accordion |
Snapshot |
oj-button |
Button |
oj-legend |
· Excluded · Included |
oj-object-migration-canvas |
Canvas |
This section includes the keystroke reference details for the Object Security Module. This module includes the following screens:
This section includes the keystroke reference details for the Metadata Browser Module.
The following table lists all the elements of the Metadata Browser Module, and the associated keystroke combinations to access them.
UI Control |
oj-tabs |
· Tabs |
oj-tabs |
· Dashboard · Search · Catalog of objects · Applications |
oj-button |
Filter |
oj-button |
Reload |
oj-button |
Publish |
oj-button |
Map |
oj-chart |
Chart |
oj-legend |
Legend |
oj-chart |
Chart |
oj-button |
Apply |
oj-checkbox |
· Show common objects only · Data Foundation |
available-objects-list
List View |
selected-objects-list |
List View |
oj-button |
Select |
oj-button |
Select All |
oj-button |
Deselect |
oj-button |
Deselect All |
oj-button |
Cancel |
oj-button |
Save |
oj-input-search |
Metadata Browser Search |
oj-list-view |
List View |
oj-foldable-layout |
Foldable Layout |
oj-button |
Export to PDF |
oj-button |
More |
oj-button |
Details |
oj-tree-view |
Tree |
oj-dialog |
Dialog |
oj-dialog |
Dialog |
oj-table |
· Used in · Depends on |
oj-tabs |
Tabs |
metadata-browser-breadcrumbs |
Breadcrumbs |
object-node |
Object Node |
object-node |
Object Node |
oj-menu |
Menu |
oj-list-view and oj-foldable-layout |
List View and Foldable Layout |
oj-messages |
Messages |
This section includes the keystroke reference details for the Utilities Module. It includes the following screens:
The following table describes all the elements of the Utilities – Metadata Difference Section and the Keystroke combinations to access them.
UI Control |
html5-metadata-treecontrol
Select Metadata Tree Control |
html5-metadata-treebrowser
Select Metadata Tree Browser |
html5-button
Show Difference |
html5-button
Reset |
html5-button
Help |
The following table describes all the elements of the Metadata Authorization Section and the keystroke combinations to access them.
UI Control |
html5-tab
Business Metadata |
html5-grid |
Business Metadata Grid |
html5-button
Help |
The following table describes all the elements of the Save Metadata Section and the keystroke combinations to access them.
UI Control |
html5-radiobutton
· Hierarchy · Derived Entity |
html5-dataset-hierarchy-browse |
Available Metadata |
html5-button |
Save |
html5-button |
Reset |
html5-button |
Help |
The following table describes all the elements of the Write Protected Batch Section and the keystroke combinations to access them.
UI Control |
html5-grid |
· Batch Name · Batch Description · Write-Protected Batch |
html5-checkbox |
html5-button |
Check All |
html5-button |
Uncheck All |
html5-button |
Save |
html5-button |
Cancel |
html5-button |
Help |
The following table describes all the elements of the Component Registration section and the keystroke combinations to access them.
UI Control |
html5-button |
New |
html5-button |
Edit |
html5-button |
Remove |
html5-tab
Component Registration |
oj-tree |
Available Components |
html5-textbox |
· Component ID · Class Path · Image Name · Tree Order |
html5-select-one
· Parent ID · ICC Component ID |
html5-button |
Save |
html5-button |
Cancel |
html5-button |
Help |
oj-textbox |
· Created By · Creation Date · Last Modified By · Modification Date |
The following table describes all the elements of the Transfer Document Ownership Section and the keystroke combinations to access them.
UI Control |
html5-radiobutton
· Users · User Groups |
html5-select-one
· User · Destination User |
html5-dataset-hierarchy-browser |
· Available Documents · Selected Documents |
html5-button |
Save |
html5-button |
Reset |
html5-icon
Help |
The following table describes all the elements of the Patch Information Section and the keystroke combinations to access them.
UI Control |
html5-tab
Patch Information |
html5-textbox |
· Textbox: · Patch or Application Name · Information Domain |
html5-icon
Help |
html5-button |
Search |
html5-button |
Reset |
html5-pagination |
· Records per Page |
html5-grid |
· Patch or Application Name · Applied Date · Information Domain · Application ID · Segment Map ID · Segment Code · Additional Information |
This section includes the keystroke reference details for the Process Modelling Framework Module. This module includes the following screens:
· Process Modeller/Process Monitor
Figure 10: Process Modelling Framework Module
This section includes the keystroke reference details for the Process Modeller and Process Monitor Modules.
The following table lists all the elements of the Process Modeller/Process Monitor Summary Page, and the associated keystroke combinations to access them.
UI Control |
cca-pmf-breadcrumbs |
· Process Modeller · Process Monitor |
oj-input-number |
Refresh Interval (In Min) |
Summary Search |
oj-input-text |
Name |
oj-select-many |
Pipeline Filter |
oj-select-single |
· Sort By · Auto Refresh |
oj-cca-list-view |
List View |
oj-button |
· Add |
oj-button |
Process Monitor |
oj-button |
Process Modeler |
oj-button |
Process Modeller Help/Process Monitor Help |
oj-button |
Apply |
oj-button |
Refresh |
oj-button |
Search |
oj-button |
Cancel |
oj-button |
Launch Process in New Window |
oj-button |
Delete |
oj-button |
Menu |
oj-menu |
Process Modeller Menu |
oj-menu |
Process Monitor Menu |
oj-cca-pagination |
Page |
oj-input-number |
Records |
This section includes the keystroke reference details for the Process Modeller/Process Monitor details Module.
The following table lists all the elements of the Process Flow Page, and the associated keystroke combinations to access them.
UI Control |
cca-pmf-Breadcrumbs |
· Process Flow · Job ID |
oj-button |
Definition |
oj-button |
Help |
oj-button |
Timer |
oj-button |
Data Fields |
oj-button |
Application Rule |
oj-button |
Execution |
oj-button |
Save |
oj-button |
Show Entire Label |
oj-button |
Show Navigator |
oj-button |
Refresh |
oj-accordion |
Accordion |
oj-button |
Expand/Collapse button |
oj-input-text |
Search |
oj-canvas-diagram |
PMF Canvas |
The following table lists all the elements of the Process Flow – Process Details Section, and the associated keystroke combinations to access them.
UI Control |
oj-dialog |
Process Details |
oj-textbox |
· Process ID · Process Name · Process Description · Tag |
oj-select-single |
· App Package ID · Type · Registered Topics · Spark DB · Infodom · Segment |
oj-button |
Apply |
oj-button |
Close |
oj-button |
Accept |
oj-messages |
Delete Confirmation Message |
The following table lists all the elements of the Process Flow – Definition Section, and the associated keystroke combinations to access them.
UI Control |
oj-dialog |
Definition |
oj-textbox |
· Process Name · Process ID · Process Description · Created Date · Created By · Tag |
oj-button |
Apply |
oj-button |
Apply |
oj-button |
Close |
The following table lists all the elements of the Process Flow – Timer Section, and the associated keystroke combinations to access them.
UI Control |
oj-dialog |
Timer |
oj-input-text |
Search Control for: · Timer · Activity Selection · Rules Mapping |
oj-button |
Reset |
oj-button |
Add |
oj-button |
Edit |
oj-button |
Copy |
oj-button |
Back |
oj-button |
Apply |
oj-tabs |
· Details · Activity · Frequency · Rules |
oj-textbox |
· ID · Name · Description · After every (number of) Minute(s) · After every (number of) Hour(s) · Once a day · After every (number of) day(s) · After every (number of) week(s) · After every (number of) month(s) · After every (number of) years |
html5-checkbox
· Checkbox to select the Process · Checkbox to select the Decision Rule |
oj-datetime |
Applicable Date |
oj-radio |
oj-switch |
Is Enabled |
The following table lists all the elements of the Process Flow – Data Fields Section, and the associated keystroke combinations to access them.
UI Control |
oj-dialog |
Data Fields |
oj-input-text |
Data Fields |
oj-list-view |
List View for Data Fields |
oj-button |
Add |
oj-button |
Delete |
oj-button |
· WF_ENTITYID · FIC_MIS_DATE · GAAP · WF_INFODOM_CODE · WF_INSTANCE · WF_LOCALE · WF_OBJECT_ID · WF_OBJECT_NAME · WF_OBJECT_TYPE · WF_OUTCOME_ID · WF_PROCESS_ID · V_RUN_MAIN_DESC · WF_SEGMENT_CODE · WF_STATUS · WF_TASK_RESPONSE · WF_TASK_STATUS · WF_USERID · WF_CALLBACK_TASK_STATUS · WF_IN_MSG_PROP · WF_IN_MSG_REC · WF_IN_SVC_PROP · WF_LIVY_SPARK_SESSION_ID · WF_MISDATE · WF_OUT_MSG · WF_ROOT_PROCESS · WF_RUNSK · WF_SVC_PROP_VALUE_1 · WF_SVC_PROP_VALUE_2 · WF_SVC_PROP_VALUE_3 · WF_SVC_PROP_VALUE_4 · WF_SVC_PROP_VALUE_5 · WF_SVC_PROP_VALUE_6 |
oj-button |
Back |
oj-button |
Apply |
oj-textbox |
· Data Field Code · Data Field Description · Initial Value |
oj-select-single |
· Data Field Type · Is Mandatory · Scope |
The following table lists all the elements of the Process Flow – Application Rule Section, and the associated keystroke combinations to access them.
UI Control |
oj-dialog |
Application Rule |
oj-input-text |
Application Rule |
oj-list-view |
List View for Application Rule |
oj-button |
Add |
oj-button |
Delete |
oj-button |
Help |
oj-button |
· Default · Outcome Approve · Outcome Reject · Outcome Submit |
oj-button |
Back |
oj-button |
Apply |
oj-textbox |
· Name · Implementation Detail · Procedure Name · Input Parameters · Parameter Mode · Function Name · Class Name · Method · URL · Query Param · Headers · Data · Expression · JSON Path Expression · RHS Expression · Table Name · Source JSON · Column List · Where Condition |
oj-select-single |
· Application Rule Type · Rule Type · Execution Type · Method Type · Return Parameter · Scope · Authorization Type · Is Proxy Required · Outcomes · Expression Type · Attribute · RCY · Condition · JSON Input · Operator · Output Data Field · Return JSON Type |
html5-new-expression-builder |
Expression Builder |
The following table lists all the elements of the Process Flow – Execution Section, and the associated keystroke combinations to access them.
UI Control |
oj-dialog |
Execution Dialog with parameters |
oj-dialog |
Execution Dialog without parameters |
oj-select-single |
· Execution Type · By · Criteria · Consolidation Type · Intra Company Elimination |
oj-datetime |
FIC MIS Date |
oj-textbox |
· Object ID · Application Params (in JSON format) · Run Execution Description |
oj-text-input |
· Consolidation Hierarchy · Reporting Currency · Legal Entity |
oj-text-input |
NOTE: Clicking on the link icon opens the AMHM screen. |
GAAP Code |
oj-button |
Browser launch button |
oj-button |
Apply |
oj-button |
Search |
oj-button |
Reset |
oj-button |
Cancel |
oj-button |
Ok |
oj-button |
Close |
oj-button |
Search |
oj-button |
Sort with Path |
oj-button |
Sort Hierarchy (Top to Bottom) |
oj-button |
Sort Level (High to Low) |
oj-button |
Expand All |
oj-button |
Collapse All |
oj-button |
Expand Branch |
oj-button |
Collapse Branch |
oj-button |
Focus |
oj-button |
Unfocus |
oj-button |
Show Unique Code Values (Right) |
oj-button |
Show Alphanumeric Code Values (Right) |
oj-button |
Previous |
oj-button |
Next |
oj-button |
Search |
oj-button |
Reset |
oj-tabs |
· Show Hierarchy · Show Results |
oj-hierarchy-browser-shuttle |
Hierarchy Browser |
The following table lists all the elements of all the PMF Activities in the Process Modeller and Process Monitor, and the associated keystroke combinations to access them. The PMF Activities are Start, Human Task, Service Task, Sub Pipeline, Parallel Gateway, Sequential Gateway, Multichoice Gateway, Connector, RuleType3, MFModel, Run, DataQualityGroups, RunExecutable, LoadT2T, TransformDT, and RuleType2.
UI Control |
oj-dialog |
· Job_ID · Edit Transition · Add New Transition · Application Rule · Load T2T · T2T Activity · Parallel Activity · TransformDT · Start · Participant Details · Action · Notification Details · Notification Group · RuleType3 · MFModel · DataQualityGroups · RunExecutable · Run · (Human Task) |
oj-tabs |
· Activity · Transition · Logs · Implementation · Action · Notification |
oj-tabs |
· Task Details · Escalation · Reminder · Notification |
oj-button |
Add |
oj-button |
Execution Logs |
oj-button |
Transition |
oj-button |
Delete |
oj-button |
Group Approval |
oj-button |
Search |
oj-button |
Reset |
oj-button |
View Log |
oj-button |
Download |
oj-button |
Apply |
oj-textbox |
· Activity Name · Activity ID · Activity Desc · Activity Description · Activity Type · Transition Name · Order · Execution Rule · Wild Card · Outcomes · Task ID · Task Name · Maximum Escalation Level · Custom Escalation Java Class · Recurrence · ID · Role Code · Notification name · Data File Address · Default Value · Parameter List · Optional Parameters · Rejection Threshold · Additional Parameters · Executable · Run Parameters |
oj-select-single |
· Status · Exclude Task · Connected To · Stroke · Infodom · Component · Log File · Data Fields · Parameter Type · Generate · Enabled · Expiry · Escalation · Escalation Path · Notification Message · Email Required · Email Template · Relative Date · Notification Message · User Type · Notification ID · Datastore Name · Load Mode · Source Name · File Name · Rule Name · Rule Code · Build Flag · Model Code · Operation · Fail if Threshold Breaches · DQ Group Name · Wait · Batch Parameter · Run Type · Execution Rule |
oj-input-text |
· Decision Rule · Execution Rule · Pre Rule · Post Rule · Condition · User |
oj-list-view |
· Job ID · Application Rule · Participant Details · Parameters · Implementation · Transition · Action · Notification |
oj-control-specific-help |
Control specific help |
oj-input-text |
Search Control for: · Application Rule · Participant Details |
oj-radio |
· Default · Outcome Approve · Outcome Reject · Outcome Submit · Selection · Select · FSDFADMIN · FSDFANLST · FSDFDMODLR · FSDFOPRTR · IDENTITYMGMTADMIN · IDENTITYMGMTAUTH · SYSTEMADMIN · Enabled Yes · Enabled No · Email Required Yes · Email Required No |
oj-collapse |
· View Logger · Log File Contents |
oj-input-number |
· Expiry Days · Escalation After · Duration |
oj-datetime |
FIC MIS Date |
oj-textarea |
Log File Contents |
For information about the Application Rule UI controls, see the section Application Rule Section.
The following table lists all the elements of the Process Flow Sub-Process Details Section, and the associated keystroke combinations to access them.
UI Control |
oj-dialog |
· FSDF Sub-Process · Transition · Edit Transition · Add New Transition · Application Rule |
oj-textbox |
· Activity Name · Activity Desc · Activity Type · Transition Name · Order |
oj-select-single |
· Status · App Package ID · Process ID · Object ID · Object Type · Data Field Pass · Calling Mode · Exclude Task · Connected To · Stroke |
oj-tabs |
· Activity · Transition |
oj-list-view |
Job ID |
oj-input-text |
Decision Rule |
oj-input-text |
Application Rule |
oj-radio |
oj-button |
Save |
See the Application Rule Section , for information about the Application Rule UI Controls.
The following table lists all the elements of the Process Modeller – Filter section, and the associated keystroke combinations to access them.
UI Control |
oj-dialog |
Filter |
oj-select-single |
· Filter Hierarchy · Filter List |
oj-list-view |
List View for the selected Filter value |
oj-button |
Add |
oj-button |
Expand |
oj-button |
Delete |
oj-button |
Apply |
oj-button |
Search |
oj-button |
Reset |
oj-button |
Cancel |
oj-button |
Ok |
oj-button |
Close |
oj-button |
Search |
oj-button |
Sort with Path |
oj-button |
oj-button |
oj-button |
Expand All |
oj-button |
Collapse All |
oj-button |
Expand Branch |
oj-button |
Collapse Branch |
oj-button |
Focus |
oj-button |
Unfocus |
oj-button |
oj-button |
oj-button |
Previous |
oj-button |
Next |
oj-button |
Search |
oj-button |
Reset |
oj-tabs |
The following table lists all the elements of the messages in the Process Modelling Framework, and the associated keystroke combinations to access them.
UI Control |
oj-messages |
· Delete Node Job_ID · Create a Copy of Node |
oj-button |
Confirm Delete |
oj-button |
Close |
oj-button |
Save |
