Powering On the LSMS
For information about powering on the LSMS servers (LSMSPRI and LSMSSEC), refer to Application B Card Hardware and Installation Guide.
Note: Powering on the LSMS servers (which can be done in any order) does not start the LSMS application and MySQL database services. To start those functions after restoring power to the servers, perform the following steps:
  1. Log in to LSMSPRI as lsmsmgr.
    (For information about logging in, see “Logging In to LSMS Server Command Line”.)
  2. Select Maintenance > Start Node to initiate the following activities:
    • Uninhibit LSMSPRI
    • Transition LSMSPRI to the HAACTIVE state
      Note: The database on LSMSPRI becomes the master.
  3. Log in to LSMSSEC as lsmsmgr.
  4. Select Maintenance > Start Node to initiate the following activities:
    • Copy the database on LSMSPRI to LSMSSEC
    • Begin database replication on LSMSSEC.
      Note: The LSMSSEC database becomes a slave.
    • HA uninhibits LSMSSEC, allowing LSMSSEC to transition to a HASTANDBY state
      LSMSPRI is now active and running the LSMS application; LSMSSEC is in a standby state.
