You can log into the LSMS active server or into a specific server from any terminal that has a Secure Shell (ssh) client installed.
You must have a user ID and password before you can log in to LSMS.
ssh -X <username>@<server_IP_address>
For <username> and <server_IP_address>, specify values shown in Table 1 that are appropriate to the procedure you are performing:
| Parameter |
Value |
| <username> |
Use one of the following:
| <server_IP_address> |
In this manual, menu selections are indicated as a series; for example, select Maintenance > Start Node indicates that you should highlight the Maintenance item on the main menu, press Enter, then highlight the Start Node item on the next menu, and press Enter.
[lsmsadm@lsmspri lsmsadm] $
LSMS commands can be entered at this prompt. If you need to start an LSMS GUI session, see Starting an Web-Based LSMS GUI Session.
