To set up files to be transferred automatically, perform the following procedure. It is recommended that you schedule transfers according to the following guidelines:
Transferring large numbers of files does not impact the processing performance of the LSMS, but it can impact network performance, especially networks that use the single-subnet design. (For more information about network design, refer to the LSMS Configuration Manual.). This feature is designed for insignificant network degradation for up to 10 configured remote locations with up to 600 transferred files.
