Displays, adds, and deletes remote locations and scheduled transfers.
autoxfercfg
The user must be defined as a member of the secondary group lsmsadm.
$LSMS_DIR/autoxfercfg [-h]
None.
None.
Select one of the following menu options: 1) Display valid remote locations 2) Add new remote location 3) Remove remote location 4) Display all scheduled transfers 5) Add new scheduled transfer 6) Remove scheduled transfer 7) Exit
For more information about using this menu, see one of the following:
| Exit Code |
Message |
Cause |
Suggested Recovery |
| 1 |
Feature not enabled |
The Automatic File Transfer feature is not installed. |
Contact Oracle to schedule installation and activation of the feature. |
| 2 |
Only user ‘lsmsadm’ can run this program |
The user that tried to run this program was not the user lsmsadm. |
Change user to lsmsadm. |
| 3 |
Configuration utility already running |
The autoxfercfg command has already been entered, but not yet exited. |
No action necessary. |
| 4 |
Unable to open <home>/.netrc (where <home> is the home directory of the user) |
The file permissions for $HOME/.netrc are not set correctly. |
Change permissions on the $HOME/.netrc file. |
The following files associated with the autoxfercfg command.
| Filename |
Type |
Location |
.netrc |
Autologin resource file for ftp |
$HOME |
crontab |
List of scheduled cron jobs |
$HOME |
autoxfer.cfg |
Configuration file |
/usr/TKLC/lsms/config |
