Displaying Remote Locations Used for Automatic File Transfers
To display all remote locations that have been previously added using this feature, perform the following procedure.
Log in to the active server as lsmsadm.
Enter the following command (for more information about the format of this command, see “autoxfercfg”):
$ $LSMS_DIR/autoxfercfg
The following menu is displayed:
Select one of the following menu options:
1) Display valid remote locations
2) Add new remote location
3) Remove remote location
4) Display all scheduled transfers
5) Add new scheduled transfer
6) Remove scheduled transfer
7) Exit
Enter 1.
Output similar to the following displays:
Valid remote machine names:
1. lnp3
2. ftp.lnp25
<hit any key to continue>
After you have pressed any key, the output displayed in step 3 is displayed again.
If you desire to perform other functions, enter a number and follow the procedure described in one of the other sections that describe this feature. For a list of the sections, Managing Automatic File Transfers.
If you do not need to perform any other function, type 7.
