To remove an automatic transfer that has been previously set up using this feature, perform the following procedure.
Note: Any file transfers that have been set up to be performed one time only cannot be removed.
Log in to the active server as lsmsadm.
Enter the following command (for more information about the format of this command, see “autoxfercfg”):
$LSMS_DIR/autoxfercfg
The following menu is displayed:
Select one of the following menu options:
1) Display valid remote locations
2) Add new remote location
3) Remove remote location
4) Display all scheduled transfers
5) Add new scheduled transfer
6) Remove scheduled transfer
7) Exit
Enter 6.
Output similar to the following displays to show all currently scheduled transfers. Enter the number of the transfer that you want to remove (in this example, the first transfer is to be removed. as shown by 1, in bold), or enter 0 to quit:
Scheduled transfer successfully removed.
<hit any key to continue>
After you have pressed any key, the output displayed in step 3 is displayed again.
If you desire to perform other functions, enter a number and follow the procedure described in one of the other sections that describe this feature. For a list of the sections, Managing Automatic File Transfers.
If you do not need to perform any other function, type 7.
