3000000000010000 - Server Power Feed Error
This alarm indicates that one of the power feeds to the server has failed.
Recovery
  1. Locate the server supplied by the faulty power feed. Verify that all connections to the power supply units are connected securely. To determine where the cables connect to the servers, see the Power Connections and Cables page of the NAS on LSMS E5-APP-B Interconnect.
  2. Run syscheck.
    1. If the alarm is cleared, the problem is resolved.
    2. If the alarm is not cleared, go to the next step.
  3. Trace the power feed to its connection on the power source.
    Verify that the power source is on and that the power feed is properly secured.
  4. Run syscheck.
  5. If the power source is functioning properly and all connections are secure, request that an electrician check the voltage on the power feed.
  6. Run syscheck.
  7. If the problem is not resolved, call the My Oracle Support (MOS) for assistance.
  8. Run savelogs_plat to gather system information for further troubleshooting, (see Saving Logs Using the LSMS GUI or Command Line), and contact the My Oracle Support (MOS).
