Lets you start, stop, or display status of an instance of the NPAC Agent for a particular region.
lsms
The user must be logged in with the user name lsmsadm.
Do not start an NPAC agent unless you have already created a regional database for it (see “npac_db_setup”).
$LSMS_DIR/lsms <Action> <Region>
None.
# Stop the NPAC Agent for the Canada NPAC $ $LSMS_DIR/lsms stop Canada Checking if npacagent is running....Yes. Stopping npacagent.... OK. npacagent stopped: Wed Nov 30 16:28:26 2005 Command complete. $ # Verify that NPAC Agent has terminated $ $LSMS_DIR/lsms status Canada Checking if npacagent is running. .. .No. Command Complete. # Restart the NPAC Agent for the Canada NPAC > $ $LSMS_DIR/lsms start Canada Checking if npacagent is already running....No Starting npacagent.... Verifying....OK. npacagent started: Wed Nov 30 16:29:45 2005 Command complete.
| Exit Code |
Message |
Cause |
Suggested Recovery |
| 1 |
Checking if npacagent is already running....Yes. npacagent is already running |
Operator tried to startnpacagentwhen it was already running |
No action necessary. |
| 1 |
Checking if npacagent is running....No. npacagent is not running. |
Operator tried to stopnpacagentwhen it was already stopped |
| 3 |
lsms: bind: errornumber |
Attempt to bind UDP socket failed. errornumber is the error returned by bind. |
Contact the My Oracle Support (MOS). |
| 3 |
lsms: exec: errornumber |
Attempt to exec npacagent process failed. errornumber is the error returned by exec. |
| 1 |
lsms: Failed to start npacagent |
Execution of npacagent failed |
| 1 |
lsms: Failed to stop npacagent |
Attempt to stop npacagent failed |
| 2 |
lsms:LSMS_DIR is not defined |
LSMS_DIR environment variable is not set |
Verify the environment variables. |
| 3 |
lsms: send: errornumber |
Attempt to send command to agent failed. errornumber is the error returned by send. |
| 3 |
lsms: socket: errornumber |
Attempt to open UDP socket failed. errornumber is the error returned by socket. |
| 2 |
npacagent: Permission denied for npacagent or executable not found. |
Operator does not have permission to execute this command or executable could not be found. The operator must be an lsmsadm user. |
Change user to lsmsadm or lsmsall and try the command again. If the error persists, contact the My Oracle Support (MOS). |
| 2 |
Unknown region ==>< region name > must be one of the following:
Invalid NPAC region specified |
Try the command again with a valid region name. |
| 2 |
Usage: lsms [ start | stop ] <region> |
Invalid action specified |
Try the command again with correct syntax. |
