5000000000000001 - Server Disk Space Shortage Warning
This alarm indicates that one of the following conditions has occurred:
Recovery
  1. Run syscheck.
  2. Examine the syscheck output to determine if the file system /var/TKLC/lsms/free is low on space. If it is, continue to the next step; otherwise go to Step 4.
  3. If possible, recover space on the free partition by deleting unnecessary files:
    1. Log in to the server generating the alarm as the root user:
      Login: root
      Password:<Enter root password>
    2. Change to the /var/TKLC/lsms/free directory: # cd /var/TKLC/lsms/free
    3. Confirm that you are in the /var/TKLC/lsms/free directory: # pwd /var/TKLC/lsms/free
    4. When the pwd command is executed, if /var/TKLC/lsms/free is not output, go back to Sub-step b
    5. List files to be deleted and delete them using the rm command
    6. Re-run syscheck
    If the alarm is cleared, the problem is solved. If the alarm is not cleared, go to the next Step.
  4. Run savelogs to gather all application logs (see Saving Logs Using the LSMS GUI or Command Line).
  5. Contact the My Oracle Support (MOS).
