Using the hastatus Command to Determine the Server Status
To use the command line to determine the state an individual server, perform the following procedure.
  1. Log in as the lsmsadm or lsmsall user to the command line of the server whose state you want to determine.
    (For information about logging in, see “Logging In to LSMS Server Command Line”.)
  2. Enter the following command:
    $ hastatus
  3. The command line interface displays the status, similar to the following example, and then returns the prompt.
    ACTIVE
