# /usr/TKLC/plat/bin/syscheck -v lsmshc proc
The following sample output from syscheck -v proc run indicates which processes are configured to be running on the active server and that all expected instances of the processes are running:
Running modules in class proc...
run: Checking supman...
run: Found 1 instance(s) of the supman process.
run: Checking lsman...
run: Found 1 instance(s) of the lsman process.
run: Checking npacagent...
run: Found 1 instance(s) of the npacagent process.
run: Checking eagleagent...
run: Found 2 instance(s) of the eagleagent process.
run: Checking rmtpmgr...
run: Found 1 instance(s) of the rmtpmgr process.
run: Checking rmtpagent...
run: Found 1 instance(s) of the rmtpagent process.
run: Checking reportman...
run: Found 1 instance(s) of the reportman process.
run: Checking lsmslogd...
run: Found 1 instance(s) of the lsmslogd process.
run: Checking sentryd...
run: Found 1 instance(s) of the sentryd process.
run: Checking survMon...
run: Found 1 instance(s) of the survMon process.
run: Checking smartd...
run: Found 1 instance(s) of the smartd process.
run: Checking atd...
run: Found 1 instance(s) of the atd process.
run: Checking crond...
run: Found 1 instance(s) of the crond process.
run: Checking sshd...
run: Found 7 instance(s) of the sshd process.
run: Checking syscheck...
run: Found 1 instance(s) of the syscheck process.
run: Checking syslogd...
run: Found 1 instance(s) of the syslogd process.
Return string: "OK"
OK
The log is available at:
-->/var/TKLC/log/syscheck/fail_log
If you see FAILURE (similar to the following example) for any process except the GUI process, contact the My Oracle Support (MOS): run: Only 0 instance(s) of lsmslogd running. 1 instance(s) required.The following sample output from syscheck -v lsmshc proc indicates which processes are configured to be running on the active server and that all expected instances of the processes are running:
Running modules in class lsmshc...
proc: Node active, checking
proc: Checking supman...
proc: Found 1 instance(s) of the supman process.
proc: Checking lsman...
proc: Found 1 instance(s) of the lsman process.
proc: Checking npacagent...
proc: Found 1 instance(s) of the npacagent process.
proc: Checking eagleagent...
proc: Found 1 instance(s) of the eagleagent process.
proc: Checking rmtpmgr...
proc: Found 1 instance(s) of the rmtpmgr process.
proc: Checking rmtpagent...
proc: Found 1 instance(s) of the rmtpagent process.
proc: Checking reportman...
proc: Found 1 instance(s) of the reportman process.
proc: Checking lsmslogd...
proc: Found 1 instance(s) of the lsmslogd process.
proc: Checking sentryd...
proc: Found 1 instance(s) of the sentryd process.
Return string: "OK"
OK
