Perform the tests in the order shown in Table 1 to verify that the LSMS is fully functional following file system restoration. If any of these tests fail, contact the My Oracle Support (MOS).
| Condition to Verify |
Test to Perform |
| 1 |
One server is in ACTIVE state and the other server is in STANDY state |
| 2 |
The appropriate software processes are running on the primary server |
| 3 |
The GUI process can be started on the primary server |
| 4 |
Switchover can be performed from the active server to the standby server |
Manually Switching Over from the Active Server to the Standby Server |
| 5 |
The appropriate software processes can be run on the newly active server |
| 6 |
The GUI process can be started on the newly active server |
| 7 |
| 8 |
| 9 |
