Verifying the GUI Operability on the Active Server
Perform the following procedure to verify that the LSMS graphical user interface will open:
  1. Perform the procedure described in “Logging In to LSMS Server Command Line” using the hostname of the active server.
  2. Perform the procedure described in Starting an Web-Based LSMS GUI Session, using an NPAC-provided Service Provider ID.
  3. Select Exit/Logout from the User/Session menu on the LSMS Console window.
    The console logout window displays. Click OK to complete the logout.
