Event Descriptions
0001
Explanation
The EMS Ethernet interface has a problem. The ping utility did not receive a response from the interface associated with the EMS.
Recovery
Consult with your network administrator.
Event Details
Table 1. Event 0001 Details
GUI Notification
Severity
None
Text
Surveillance Notification
Text
Notify:Sys Admin - EMS interface failure
Source
Both servers
Frequency
Every 2.5 minutes as long as condition exists
Trap
Trap ID
16
Trap MIB Name
emsInterfaceFailure
0002
Explanation
The EMS, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text, requires a resynchronization with the LSMS that cannot be accomplished by automatic resynchronization between the LSMS and the EMS.
Recovery
Perform one of the synchronization procedures described in the LNP Database Synchronization User's Guide.
Event Details
Table 2. Event 0002 Details
GUI Notification
Severity
Critical
Text
DB Maintenance Required
Text
Notify:Sys Admin - NE CLLI=<CLLI>
Source
Active server
Frequency
As soon as condition occurs, and at five-minute intervals as long as condition exists
Trap
Trap ID
33
Trap MIB Name
emsRequiresResynchWithLSMS
0003
Explanation
The LSMS has lost association with the primary EMS of the network element, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text; the association with the secondary EMS is established.
Recovery
Determine why the primary association failed (connectivity problem, EMS software problems, NE software problem, etc.). Correct the problem. Association will be automatically retried.
Event Details
Table 3. Event 0003 Details
GUI Notification
Severity
Major
Text
Primary Association Failed
Text
Source
Active server
Frequency
Trap
Trap ID
5
Trap MIB Name
primaryEMSAssocLostSecEstablished
0004
Explanation
The LSMS has lost association with the primary EMS of the network element, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text; the association with the secondary EMS is not established.
Recovery
Determine why the primary association failed (connectivity problem, EMS software problems, NE software problem, etc.). Correct the problem, and then reestablish the association with the primary EMS.
Event Details
Table 4. Event 0004 Details
GUI Notification
Severity
Critical
Text
Text
Source
Active server
Frequency
Trap
Trap ID
36
Trap MIB Name
primaryEMSAssocLostNoSec
0006
Explanation
The pending queue used to hold transactions to be sent to the EMS/NE, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text, is full. To help ensure that no updates are lost, the eagleagent will abort associations with both the primary EMS and secondary EMS. Updates will be queued in a resynchronization log until the EMS reassociates.
Recovery
Determine why the EMS/NE is not receiving LNP updates, and correct the problem.
Event Details
Table 5. Event 0006 Details
GUI Notification
Severity
Critical
Text
All Association(s) Aborted: Pending Queue Full
Text
None
Source
Frequency
Trap
Trap ID
97
Trap MIB Name
emsAssociationAbortedQueueFull
0007
Explanation
The network element, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text, is busy and is sending ’retry later’ in response to a message sent by the eagleagent. The eagleagent has already tried resending the same message the maximum number of times. The eagleagent has aborted associations with both the primary EMS and secondary EMS.
Recovery
Correct the problem at the network element. When the EMS reconnects with the LSMS, the LSMS will automatically resynchronize the network element’s LNP database.
Event Details
Table 6. Event 0007 Details
GUI Notification
Severity
Critical
Text
All Association(s) Aborted: Retries Exhausted
Text
None
Source
Frequency
Trap
Trap ID
98
Trap MIB Name
emsAssocAbortedMaxResend
0008
Explanation
The LSMS has lost association with the secondary EMS which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text. The association with the primary EMS is still up.
Recovery
Determine why the secondary association failed (connectivity problem, EMS software problems, NE software problem, etc.) and then reestablish the association with the secondary EMS.
Event Details
Table 7. Event 0008 Details
GUI Notification
Severity
Major
Text
Secondary Association Failed
Text
Source
Active server
Frequency
Once, as soon as condition occurs
Trap
Trap ID
130
Trap MIB Name
secondaryEMSAssocLost
0009
Explanation
The LSMS has established the first association with the network element (NE) which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text. The first association established is called the primary association. This EMS is called the primary EMS.
Recovery
No action required; this notification is for information only.
Event Details
Table 8. Event 0009 Details
GUI Notification
Severity
Cleared
Text
Primary Association Established
Text
None
Source
Frequency
Trap
Trap ID
8
Trap MIB Name
primaryEMSAssocEstablished
0010
Explanation
The LSMS has established the second association with the network element (NE) which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text. The association is established only if a primary association already exists. This EMS is called the secondary EMS.
Recovery
Event Details
Table 9. Event 0010 Details
GUI Notification
Severity
Cleared
Text
Secondary Association Established
Text
None
Source
Frequency
Trap
Trap ID
134
Trap MIB Name
secondaryEMSAssocEstablished
0011
Explanation
The primary association for the EMS/NE, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text, is either down or is inhibited, such that transactions sent to the primary EMS will not be received by the NE. Transactions are being sent to the secondary EMS instead of the primary EMS.
Recovery
Determine why the primary association failed (connectivity problem, EMS software problem, NE software problem, or other problem). Correct the problem. Association will be automatically retried. When the association is reestablished, it will be a secondary association, and the EMS will be the secondary EMS.
Event Details
Table 10. Event 0011 Details
GUI Notification
Severity
Cleared
Text
Successful Switchover Occurred to Secondary EMS
Text
None
Source
Frequency
Trap
Trap ID
139
Trap MIB Name
transactionToSecondary
2000
Explanation
The NPAC Ethernet interface has a problem. The ping utility did not receive a response from the interface associated with the NPAC.
Recovery
Event Details
Table 11. Event 2000 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - NPAC interface failure
Source
Both primary and secondary servers
Frequency
Trap
Trap ID
15
Trap MIB Name
npacInterfaceFailure
2001
Explanation
The association with the NPAC identified by <NPAC_region_ID> has been disconnected by the user.
Recovery
Examine additional GUI notifications to determine whether the LSMS is retrying the association. Follow the recovery actions described for the GUI notification.
Event Details
Table 12. Event 2001 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Disconnected
Text
Notify:Sys Admin - NPAC=<PRIMARY|SECONDARY>-<NPAC_region_ID>
Source
Active server
Frequency
Trap
Trap ID
37
Trap MIB Name
lostNPACAssoc
2002
Explanation
The LSMS is not able to confirm the physical connectivity with the NPAC, which is specified in the System field on the GUI or is indicated by <NPAC_region_ID> in the Surveillance notification.
Recovery
Check the physical connection between the LSMS and the NPAC. The problem may be in the network, a router, or both.
Event Details
Table 13. Event 2002 Details
GUI Notification
Severity
Critical
Text
LSMS Physical Disconnect with NPAC
Text
Notify:Sys Admin - NPAC=<NPAC_region_ID>
Source
Active server
Frequency
Trap
Trap ID
45
Trap MIB Name
failedNPACConnectivity
2003
Explanation
The NPAC (PRIMARY or SECONDARY, as indicated) identified by <NPAC_region_ID> rejected the association because it received a message from the LSMS that failed security checks. This can be due to one of the following:
Recovery
Do the following:
  1. Log in as lsmsadm to the active server.
  2. Enter the following command to determine what the LSMS system time is:
    $ date
  3. Contact the NPAC administrator to determine what the NPAC time is. If the NPAC time is more than five minutes different from the LSMS time, reset the LSMS system time on both servers and on the administration console using one of the procedures described in “Managing the System Clock”.
  4. After you have verified that the NPAC and LSMS times are within five minutes of each other, cause a different security key to be used by stopping and restarting the regional agent. Enter the following commands, where <region> is the name of the region in which this notification occurred:
    $LSMS_DIR/lsms stop <region> $LSMS_DIR/lsms start <region>
  5. Start the GUI again.
  6. Attempt to reassociate with the NPAC. For information about associating with an NPAC, refer to the Configuration Guide.
  7. If the problem persists, contact Oracle Technical Service.
Event Details
Table 14. Event 2003 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted by PEER: Access Control Failure
Text
Source
Active server
Frequency
Trap
Trap ID
95
Trap MIB Name
npacRejectedAssocAccessCtrlFail
2004
Explanation
The primary or secondary NPAC, identified by <NPAC_region_ID>, rejected the association because it received data that was not valid.
Recovery
Contact the NPAC administrator.
Event Details
Table 15. Event 2004 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted by PEER: Invalid Data Received
Text
Source
Active server
Frequency
Trap
Trap ID
96
Trap MIB Name
npacRejectedAssocInvalidData
2005
Explanation
The LSMS has lost association with the primary or secondary NPAC identified by <NPAC_region_ID> because the user aborted the association.
Recovery
Reassociate with the NPAC when the reason for aborting the association no longer exists. For information about associating with an NPAC, refer to the Configuration Guide.
Event Details
Table 16. Event 2005 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>]-<NPAC_region_ID> Association Aborted by User
Text
Source
Active server
Frequency
Trap
Trap ID
9
Trap MIB Name
npacAbortByUser
2006
Explanation
The LSMS did not receive an association response from the NPAC within the timeout period. The LSMS will attempt the association with the NPAC again after an interval that defaults to two minutes, but can be configured to a different value by Oracle.
Recovery
Determine whether there is a network connection problem and/or contact the NPAC administrator to determine whether the NPAC is up and running.
Event Details
Table 17. Event 2006 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Bind Timed Out - Auto Retry After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
As soon as condition occurs, and at two-minute intervals as long as condition exists
Trap
Trap ID
100
Trap MIB Name
assocRespNPACTimeout
2007
Explanation
The NPAC association attempt was rejected by the NPAC, and the LSMS was informed to attempt the NPAC association again to the same NPAC host after an interval that defaults to two minutes, but can be configured to a different value by Oracle.
Recovery
No action required; the LSMS will automatically try to associate again.
Event Details
Table 18. Event 2007 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted by PEER - Auto Retry Same Host After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
Trap
Trap ID
101
Trap MIB Name
assocRejectedRetrySameHost
2008
Explanation
The NPAC association attempt was rejected by the NPAC, and the LSMS was informed to attempt the NPAC association again to the other NPAC host after an interval that defaults to two minutes, but can be configured to a different value by Oracle.
Recovery
Event Details
Table 19. Event 2008 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>]-<NPAC_region_ID>- Connection Aborted by PEER - Auto Retry Other Host After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
Trap
Trap ID
102
Trap MIB Name
assocRejectedRetryOtherHost
2009
Explanation
A problem exists in the network connectivity. The LSMS will attempt the association with the NPAC again after an interval that defaults to two minutes, but can be configured to a different value by Oracle.
Recovery
Check the network connectivity for errors. Verify the ability to ping the NPAC from the LSMS.
Event Details
Table 20. Event 2009 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted by PROVIDER - Auto Retry Same Host After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
Trap
Trap ID
103
Trap MIB Name
nwtkProblemRetryNPACAssoc
2010
Explanation
The LSMS received three consecutive responses from the NPAC with a download status of failure from a recovery action request. The LSMS has aborted the association and will attempt to associate again after a retry interval that defaults to five minutes, but can be configured to a different value by Oracle. The LSMS will retry the recovery action after the association is reestablished.
Recovery
Event Details
Table 21. Event 2010 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted Due to Recovery Failure - Auto Retry After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
Trap
Trap ID
104
Trap MIB Name
lsmsAbortedNPACassocDowRecFail
2011
Explanation
The LSMS has disconnected the association with the NPAC region in question due to the lack of a response to heartbeat messages from the LSMS to the NPAC.
Recovery
Contact the My Oracle Support (MOS).
Event Details
Table 22. Event 2011 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Disconnected by Heartbeat
Text
Source
Active server
Frequency
Trap
Trap ID
111
Trap MIB Name
lostNPACAssoc
2012
Explanation
The NPAC (primary or secondary, as indicated) identified by <NPAC_region_ID> rejected the association because of an access control failure. This can be due to one of the following:
Recovery
Do the following:
  1. Verify that the correct PSEL, SSEL, TSEL, and NSAP values have been configured for the OSI Presentation Address (for more information, refer to “Viewing a Configured NPAC Component” in the Configuration Guide). If you need to change the values, use the procedure described in “Modifying an NPAC Component” in the Configuration Guide.
  2. Verify that the configured Service Provider ID (SPID) is the same as the SPID assigned by the NPAC. For more information about this configuration file, refer to “Modifying LSMS Configuration Components” in the Configuration Guide.
  3. Verify that the configured NPAC_SMS_NAME is the same as the value assigned by the NPAC (this field is case-sensitive). For more information about this configuration file, refer to “Modifying an NPAC Component” in the Configuration Guide.
  4. Log in as lsmsadm to the active server.
  5. Enter the following command to determine what the LSMS system time is:
    $ date
  6. Contact the NPAC administrator to determine what the NPAC time is. If the NPAC time is more than five minutes different from the LSMS time, reset the LSMS system time on both servers and on the administration console by performing one of the procedures described in “Managing the System Clock”.
  7. After you have verified that the NPAC and LSMS times are within five minutes of each other, cause a different security key to be used by stopping and restarting the regional agent. Enter the following commands, where <region> is the name of the region in which this notification occurred:
    $ $LSMS_DIR/lsms stop <region> $ $LSMS_DIR/lsms start <region>
  8. Start the GUI again.
  9. Attempt to reassociate with the NPAC.
  10. If the problem persists, contact Oracle Technical Service.
Event Details
Table 23. Event 2012 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Attempt Failed: Access Control Failure
Text
Source
Active server
Frequency
Trap
Trap ID
106
Trap MIB Name
assocRejDueToAccessControl
2014
Explanation
The userInfo value in the cmipUserInfo portion of the NPAC association response CMIP message is not valid.
Recovery
Contact the NPAC administrator to determine why the NPAC is sending an invalid association response.
Event Details
Table 24. Event 2014 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Attempt Failed: Invalid Data Received
Text
Source
Active server
Frequency
Trap
Trap ID
108
Trap MIB Name
npacConnFailedCMIP
2015
Explanation
The NPAC association was terminated gracefully by the NPAC.
Recovery
According to the NANC specifications, this should never occur; if this message is seen, contact the NPAC administrator for the reason for the association unbind.
Event Details
Table 25. Event 2015 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Disconnected by NPAC
Text
Source
Active server
Frequency
Trap
Trap ID
109
Trap MIB Name
npacAssocGracefullyTerminated
2018
Explanation
The LSMS was unable to properly resynchronize (with the NPAC) the data that was lost while the LSMS was not associated with the NPAC.
Recovery
Do the following:
  1. Abort the NPAC association (refer to the Configuration Guide).
  2. Attempt to reassociate with the NPAC (refer to the Configuration Guide).
  3. If the reassociation is not successful, contact the NPAC and contact the My Oracle Support (MOS).
Event Details
Table 26. Event 2018 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Recovery Failed
Text
None
Source
Frequency
Trap
Trap ID
112
Trap MIB Name
lsmsDataLostBadResynch
2019
Explanation
The LSMS data lost during the resynchronization time was not resynchronized properly with the NPAC.
Recovery
Do the following:
  2. Reestablish the NPAC association (refer to the Configuration Guide).
  3. Determine whether notification 8055 NPAC <PRIMARY|SECONDARY> Recovery Complete is posted. If instead notification 2019 reappears, perform a resynchronization for a period of time starting one hour before the 2019 notification first appeared, using either the GUI (refer to “Resynchronizing for a Defined Period of Time Using the GUI” in the Database Administrator's Guide).
  4. If 2019 continues to appear, contact the My Oracle Support (MOS).
Event Details
Table 27. Event 2019 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Recovery Partial Failure
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Recovery Failure
Source
Active server
Frequency
Once , as soon as condition occurs
Trap
Trap ID
113
Trap MIB Name
badNPACresynchTime
2020
Explanation
The LSMS aborted the NPAC association because the LSMS received a message from the NPAC that did not have the correct LSMS key signature.
Recovery
Verify that the correct keys are being used by both the NPAC and the LSMS.
Event Details
Table 28. Event 2020 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Security Violation. Association Aborted. Retrying
Text
Source
Active server
Frequency
Trap
Trap ID
114
Trap MIB Name
assocAbortedBadKeys
2021
Explanation
An associate retry timer was in effect. The retry attempt was canceled because a GUI user issued an Associate, Abort or Disconnect request. If an Associate request was issued, the association is attempted immediately.
Recovery
No action required; for information only.
Event Details
Table 29. Event 2021 Details
GUI Notification
Severity
Major
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Automatic Association Retry Canceled
Text
None
Source
Frequency
Trap
Trap ID
122
Trap MIB Name
npacAutoAssociationRetryCanceled
2022
Explanation
Either the LSMS did not receive any response from the NPAC before a timeout expired or the LSMS received a response from the NPAC with a download status of failure from a recovery action request. The NPAC is unable to process the recovery action due to a temporary resource limitation. The LSMS will retry the request for the number of times indicated by <retry_number> with the interval between each retry indicated by <retry_interval> minutes. If recovery is not successful after the indicated number of retries, the LSMS will abort the association and post the following notification:
[Critical]: <Timestamp>  2010
:  NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted Due to Recovery Failure - Auto Retry After NPAC_RETRY_INTERVAL
Recovery
Event Details
Table 30. Event 2022 Details
GUI Notification
Severity
Major
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Fail/No Response from NPAC Recovery - Auto Retry <retry_number> Times in <retry_interval> Minutes
Text
None
Source
Frequency
Trap
Trap ID
123
Trap MIB Name
npacRecoveryFailureResourceLimit
2023
Explanation
The NPAC association will be down for the specified period of time (from the first time field shown in the notification to the second time field shown in the notification) due to NPAC-scheduled down time.
Recovery
When the scheduled down time is over, manually reestablish the NPAC association. For information about aborting and reestablishing an association, refer to the Configuration Guide.
Event Details
Table 31. Event 2023 Details
GUI Notification
Severity
Major
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] ScheduleDownTime from [<YYYYMMDDhhmmss>] to [<YYYYMMDDhhmmss>]
Text
None
Source
Frequency
Trap
Trap ID
124
Trap MIB Name
npacAssocPeriodDown
2024
Explanation
An Associate request has been sent to the NPAC after a retry timer expired.
Recovery
Event Details
Table 32. Event 2024 Details
GUI Notification
Severity
Major
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Timer Expired - Resending Association Request
Text
None
Source
Frequency
Trap
Trap ID
125
Trap MIB Name
npacAssocRequestSentAfterRetryTimer
2025
Explanation
The NPAC association was successfully established.
Recovery
Event Details
Table 33. Event 2025 Details
GUI Notification
Severity
Cleared
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Successfully Established
Text
None
Source
Frequency
Trap
Trap ID
7
Trap MIB Name
npacAssocEstablished
4000
Explanation
The active server has initiated an automatic switchover to the inactive server.
Recovery
Event Details
Table 34. Event 4000 Details
GUI Notification
Severity
Event
Text
Switchover Initiated
Text
Notify:Sys Admin - Switchover initiated
Source
Active server
Frequency
Once, soon as condition occurs.
Trap
Trap ID
11
Trap MIB Name
switchOverStarted
4001
Explanation
LSMS service has been switched over.
Recovery
Event Details
Table 35. Event 4001 Details
GUI Notification
Severity
Event
Text
Switchover complete
Text
Notify:Sys Admin - Switchover complete
Source
Active server
Frequency
Trap
Trap ID
12
Trap MIB Name
switchOverCompleted
4002
Explanation
LSMS service could not be switched over to the inactive server; the inactive server was not able to start LSMS service.
Recovery
Event Details
Table 36. Event 4002 Details
GUI Notification
Severity
Event
Text
Switchover Failed
Text
Notify:Sys Admin - Switchover Failed
Source
Active server
Frequency
Once, as soon as condition occurs.
Trap
Trap ID
13
Trap MIB Name
switchOverFailed
4004
Explanation
The Ethernet interface used to connect to the application network has a problem. This interface usually connects to network-connected workstations. The ping utility did not receive a response from the interface associated with the application network.
Recovery
Event Details
Table 37. Event 4004 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - APP interface failure
Source
Either server
Frequency
Trap
Trap ID
17
Trap MIB Name
appsInterfaceFailure
4007
Explanation
Database replication has failed.
Recovery
Event Details
Table 38. Event 4007 Details
GUI Notification
Severity
Critical
Text
DB Repl Err - <dbReplErr>
Text
Notify:Sys Admin - DB repl error
Source
Both servers
Frequency
Every minute as long as condition exists.
Trap
Trap ID
21
Trap MIB Name
dataReplError
4008
Explanation
The database replication process monitor has failed.
Recovery
Event Details
Table 39. Event 4008 Details
GUI Notification
Severity
Critical
Text
DB Proc Mon Err - <dbMonErr>
Text
Notify:Sys Admin - DB monitor failure
Source
Active server
Frequency
Every five minutes as long as condition exists.
Trap
Trap ID
22
Trap MIB Name
dbMonitorFail
4009
Explanation
The server has an internal disk error.
Recovery
Event Details
Table 40. Event 4009 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Internal Disk Error
Source
Either server
Frequency
Within five minutes of the condition occurring and at five-minute intervals as long as condition exists
Trap
Trap ID
23
Trap MIB Name
internalDiskError
4011
Explanation
This notification indicates that LSMS database replication is delayed.
Recovery
No action required.
Event Details
Table 41. Event 4011 Details
GUI Notification
Severity
N/A
Text
DB Repl Info
Text
Notify:Sys Admin - DB repl info
Source
Either server
Frequency
Within five minutes of the condition occurring and every minute thereafter as long as condition exists.
Trap
Trap ID
25
Trap MIB Name
dataReplInfo
4012
Explanation
A process specified by <process_name> is utilizing 40 percent or more of the LSMS’s CPU resource and the <second_ID> indicates a specific instance of the process, as follows:
Recovery
Because this notification is posted every five minutes as long as the condition exists, you may choose to ignore this notification the first time that it appears. However, if this notification is repeated several times in a row, do one of the following:
  1. If the <process_name> is not npacagent, go to step 4. Otherwise, determine whether the npacagent is still using 40% or more of the CPU resource by entering the following command, where <region> can be optionally specified (it is the name of the region as displayed at the end of the notification text):
    $ ps -eo pid,pcpu,args | grep npacagent | grep <region>
  2. If the npacagent is still using 40% or more of the CPU resource, enter the following commands to stop the npacagent and restart it, where <region> is the name of the NPAC region whose npacagent is using 40% or more of the CPU resource:
    $ cd $LSMS_DIR
    $ lsms stop <region>
    $ lsms start <region>
  3. Repeat step 1. If the npacagent you tried to stop is still using 40% or more of the CPU resource, contact the My Oracle Support (MOS).
  4. If the <process_name> is not eagleagent, go to step 7. Otherwise, determine whether the eagleagent is still using 40% or more of the CPU resource by entering the following command, where <CLLI> can be optionally specified (it is the name of the network element as displayed at the end of the notification text):
    $ ps -eo pid,pcpu,args | grep eagleagent | grep <CLLI>
  5. If the eagleagent is still using 40% or more of the CPU resource, enter the following commands to stop the eagleagent and restart it, where <CLLI> is the Common Language Location Indicator (CLLI) of the network element whose eagleagent is using 40% or more of the CPU resource:
    $ cd $LSMS_DIR
    $ eagle stop <CLLI>
    $ eagle start <region>
  6. Repeat step 1. If the process you tried to stop is still using 40% or more of the CPU resource, contact the My Oracle Support (MOS).
  7. If the <process_name> is not eagleagent or npacagent, contact the My Oracle Support (MOS).
Event Details
Table 42. Event 4012 Details
GUI Notification
Severity
Major
Text
Process [<process_name>-<second_ID>] Utilizing High Percentage of CPU
Text
Notify:Sys Admin - [<process_name>-<second_ID>]
Source
Either server
Frequency
Trap
Trap ID
26
Trap MIB Name
cpuUtilitzationOver39
4013
Explanation
The LSMS server with default hostname lsmspri has been inhibited.
Recovery
As soon as possible, start the server by performing the procedure described in “Starting a Server”.
Event Details
Table 43. Event 4013 Details
GUI Notification
Severity
Major
Text
Primary Server Inhibited
Text
Notify:Sys Admin - Primary inhibited
Source
Server with default hostname lsmspri
Frequency
Trap
Trap ID
27
Trap MIB Name
primaryServerInhibited
4014
Explanation
The LSMS server with default hostname lsmssec has been inhibited.
Recovery
Event Details
Table 44. Event 4014 Details
GUI Notification
Severity
Major
Text
Secondary Server Inhibited
Text
Notify:Sys Admin - Secondary inhibited
Source
Server with default hostname lsmssec
Frequency
Trap
Trap ID
28
Trap MIB Name
secondaryServerInhibited
4015
Explanation
A heartbeat link is down.
Recovery
Event Details
Table 45. Event 4015 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Heartbeat failure
Source
Both servers
Frequency
Trap
Trap ID
29
Trap MIB Name
heartbeatLinkDown
4020
Explanation
The server’s swap space has exceeded the critical usage threshold (default = 95%).
Recovery
If the problem persists, contact the My Oracle Support (MOS).
Event Details
Table 46. Event 4020 Details
GUI Notification
Severity
Critical
Text
Swap space exceeds Critical
Text
Notify:Sys Admin - Swap space Critical
Source
Either server
Frequency
Trap
Trap ID
39
Trap MIB Name
swapSpaceCritical
4021
Explanation
The LSMS application or system daemon whose name has <process_name> as the first 12 characters is not running.
Recovery
No user action is necessary. The Surveillance process automatically restarts the Service Assurance process (sacw) and the sentryd process automatically restarts other processes.
Event Details
Table 47. Event 4021 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - <process_name> failed
Source
Active server
Frequency
Trap
Trap ID
40
Trap MIB Name
lsmsAppsNotRunning
4022
Explanation
The backup of the LSMS database has completed successfully.
Recovery
Event Details
Table 48. Event 4022 Details
GUI Notification
Severity
None
Text
Text
DATABASE backup complete
Source
Standby server
Frequency
Trap
Trap ID
41
Trap MIB Name
backupCompleted
4023
Explanation
The backup of the LSMS database has failed.
Recovery
Review backup output to determine why backup failed, correct the problems, and run backup script again manually.
Note: Determine whether the NAS can be reached using the ping command. If the NAS cannot be reached, restart the NAS. To restart the NAS turn the power off, then turn the power on. If the NAS can be reached, contact the My Oracle Support (MOS) for assistance.
Event Details
Table 49. Event 4023 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - DATABASE backup failed
Source
Standby server
Frequency
Trap
Trap ID
42
Trap MIB Name
backupFailed
4024
Explanation
The primary LSMS server (Server 1A) is not providing the LSMS service.
Recovery
Event Details
Table 50. Event 4024 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Primary not online
Source
Frequency
Trap
Trap ID
63
Trap MIB Name
primaryServerNotOnline
4025
Explanation
The standby server is not prepared to take over LSMS service.
Recovery
Event Details
Table 51. Event 4025 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Can't switch to standby
Source
Standby server
Frequency
Trap
Trap ID
64
Trap MIB Name
standbyNotReadyForSwitchover
4026
Explanation
The secondary LSMS server (Server 1B) is currently providing the LSMS service.
Recovery
Event Details
Table 52. Event 4026 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Secondary online
Source
Frequency
Trap
Trap ID
65
Trap MIB Name
secServerProvidingLSMSService
4027
Explanation
The standby LSMS server cannot determine the availability of the LSMS service on the active server.
Recovery
Determine if the other server is working normally. Also, verify that the heartbeat connections (eth2, eth3, and the serial cable) are connected and functioning properly
Event Details
Table 53. Event 4027 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Primary status unknown
Source
Standby server
Frequency
Trap
Trap ID
66
Trap MIB Name
secServerCannotDeterminePrimAvailability
4030
Explanation
The server’s swap space has exceeded the major usage threshold (default = 80%).
Recovery
Event Details
Table 54. Event 4030 Details
GUI Notification
Severity
Major
Text
Swap Space Warning
Text
Notify:Sys Admin - Swap space warning
Source
Both servers
Frequency
Trap
Trap ID
190
Trap MIB Name
swapSpaceWarning
4031
Explanation
A database replication error that was reported earlier by the 4007 event has now been cleared.
Recovery
No action necessary.
Event Details
Table 55. Event 4031 Details
GUI Notification
Severity
Cleared
Text
Database Replication cleared - <dbReplErr>
Text
None
Source
Frequency
Trap
Trap ID
195
Trap MIB Name
dataReplClear
4032
Explanation
A database process monitor error that was reported earlier by the 4008 event has now been cleared.
Recovery
Event Details
Table 56. Event 4032 Details
GUI Notification
Severity
Cleared
Text
Database Replication cleared - <dbMonErr>
Text
None
Source
Frequency
Trap
Trap ID
196
Trap MIB Name
dbMonitorCLear
4033
Explanation
The LSMS database failed count operation, which suggests a corrupt MySQL index.
Recovery
Event Details
Table 57. Event 4033 Details
GUI Notification
Severity
Critical
Text
Database Corrupt Index
Text
None
Source
Both servers
Frequency
Every 30 minutes.
Trap
Trap ID
200
Trap MIB Name
dbCorruptIndex
4038
Explanation
The mate server is down.
Recovery
Event Details
Table 58. Event 4038 Details
GUI Notification
Severity
Critical
Text
Mate Server Down
Text
Notify:Sys Admin - Mate Server Down
Source
Both servers
Frequency
Trap
Trap ID
205
Trap MIB Name
mateServerDown
4039
Explanation
The mate server is up.
Recovery
No action is required.
Event Details
Table 59. Event 4039 Details
GUI Notification
Severity
Cleared
Text
Mate Server Up
Text
Notify:Sys Admin - Mate Server Up
Source
Both servers
Frequency
As soon as condition clears
Trap
Trap ID
206
Trap MIB Name
mateServerUp
4100
Explanation
One or more platform alarms in the minor category exists. To determine which minor platform alarms are being reported, see “How to Decode Platform Alarms”. When the active server reports minor platform alarms that originated on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
Note: If you received Event 4100 in response to an snmpget error, contact the My Oracle Support (MOS) to have the NAS snmp daemon stopped and restarted.
Event Details
Table 60. Event 4100 Details
GUI Notification
Severity
Minor
Text
Minor Platform Alarm [hostname]: <alarm_string>
Text
Notify:Sys Admin - ALM <alarm_string>
Source
Both servers
Frequency
Trap
Trap ID
191
Trap MIB Name
minorPlatAlarmMask
4101
Explanation
All platform alarms in the minor category have been cleared. When the active server reports that all minor platform alarms have cleared on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
Event Details
Table 61. Event 4101 Details
GUI Notification
Severity
Cleared
Text
Minor Platform Alarms Cleared
Text
Notify:Sys Admin - Minor Plat alrms clear
Source
Both servers
Frequency
Trap
Trap ID
197
Trap MIB Name
minorPlatAlarmClear
4200
Explanation
One or more platform alarms in the major category exists. To determine which major platform alarms are being reported, see “How to Decode Platform Alarms”. When the active server reports major platform alarms that originated on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
Event Details
Table 62. Event 4200 Details
GUI Notification
Severity
Major
Text
Major Platform Alarm [hostname]: <alarm_string>
Text
Source
Both servers
Frequency
Trap
Trap ID
192
Trap MIB Name
majorPlatAlarmMask
4201
Explanation
All platform alarms in the major category have been cleared. When the active server reports that all major platform alarms have cleared on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
Event Details
Table 63. Event 4201 Details
GUI Notification
Severity
Cleared
Text
Major Platform Alarms Cleared
Text
Notify:Sys Admin - Major Plat alrms clear
Source
Both servers
Frequency
Once
Trap
Trap ID
198
Trap MIB Name
majorPlatAlarmClear
4300
Explanation
One or more platform alarms in the critical category exists. To determine which critical platform alarms are being reported, see “How to Decode Platform Alarms”. When the active server reports critical platform alarms that originated on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
Event Details
Table 64. Event 4300 Details
GUI Notification
Severity
Critical
Text
Critical Platform Alarm [hostname]: <alarm_string>
Text
Source
Both servers
Frequency
Once
Trap
Trap ID
193
Trap MIB Name
criticalPlatAlarmMask
4301
Explanation
Recovery
Event Details
Table 65. Event 4301 Details
GUI Notification
Severity
Cleared
Text
Critical Platform Alarms Cleared
Text
Notify:Sys Admin - Crit Plat alrms clear
Source
Both servers
Frequency
Once
Trap
Trap ID
199
Trap MIB Name
criticalPlatAlarmClear
6000
Explanation
The eagleagent process has been started.
Recovery
Event Details
Table 66. Event 6000 Details
GUI Notification
Severity
Cleared
Text
Eagleagent <CLLI> Has Been Started
Text
Notify:Sys Admin - <CLLI> started
Source
Active server
Frequency
Trap
Trap ID
1
Trap MIB Name
eagleAgentStarted
6001
Explanation
The eagleagent process has been stopped by the eagle script.
Recovery
Event Details
Table 67. Event 6001 Details
GUI Notification
Severity
Critical
Text
Eagleagent <CLLI> Has Been Stopped by User
Text
Notify:Sys Admin - <CLLI> norm exit
Source
Active server
Frequency
Trap
Trap ID
2
Trap MIB Name
eagleAgentStoppedbyscript
6002
Explanation
The npacagent for the region indicated by <NPAC_region_ID> has been started.
Recovery
Event Details
Table 68. Event 6002 Details
GUI Notification
Severity
Cleared
Text
NPACagent Has Been Started
Text
Notify:Sys Admin - <NPAC_region_ID> NPACagent started
Source
Active server
Frequency
Trap
Trap ID
3
Trap MIB Name
NPACAgentStarted
6003
Explanation
The npacagent for the region indicated by <region> has been stopped using the lsms command.
Recovery
No action required; for information only. If you desire to restart the agent, do the following:
  1. Log in to the active server as lsmsadm.
  2. Enter the following commands to start the npacagent where <region> is the name of the NPAC region:
    $ cd $LSMS_DIR
Event Details
Table 69. Event 6003 Details
GUI Notification
Severity
Critical
Text
NPACAgent Has Been Stopped by User
Text
Notify:Sys Admin - <NPAC_region_ID> norm exit
Source
Active server
Frequency
Trap
Trap ID
4
Trap MIB Name
lsmsCommandStoppedNPACAgent
6004
Explanation
The eagleagent process for the network element identified by <CLLI> has failed. The sentryd process will attempt to restart.
Recovery
No action required; the sentryd process will attempt to restart the eagleagent process.
Event Details
Table 70. Event 6004 Details
GUI Notification
Severity
Critical
Text
Eagleagent [<CLLI>] Has Failed
Text
Notify:Sys Admin - FAILD: <CLLI>
Source
Active server
Frequency
Trap
Trap ID
74
Trap MIB Name
lsmsEagleAgentFailed
6005
Explanation
The eagleagent process for the network element identified by <CLLI> has been successfully restarted by the sentryd process.
Recovery
No action required.
Event Details
Table 71. Event 6005 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RECOV: <CLLI>
Source
Active server
Frequency
Trap
Trap ID
75
Trap MIB Name
lsmsEagleAgentRestarted
6006
Explanation
The sentryd process was unable to restart the eagleagent process for the network element identified by <CLLI>.
Recovery
Event Details
Table 72. Event 6006 Details
GUI Notification
Severity
Critical
Text
Failure Restarting Eagleagent [<CLLI>]
Text
Notify:Sys Admin - RFAILD: <CLLI>
Source
Active server
Frequency
Trap
Trap ID
76
Trap MIB Name
failureToRestartEagleAgent
6008
Explanation
The npacagent process for the region specified by <NPAC_region_ID> has failed. The sentryd process will attempt to restart.
Recovery
No action required; the sentryd process will attempt to restart the npacagent process.
Event Details
Table 73. Event 6008 Details
GUI Notification
Severity
Critical
Text
NPACagent [<NPAC_region_ID>] Failure
Text
Notify:Sys Admin - FAILD: <NPAC_region_ID> agent
Source
Active server
Frequency
Trap
Trap ID
78
Trap MIB Name
NPACagentForRegionFailure
6009
Explanation
The npacagent process for the region specified by <NPAC_region_ID> has been successfully restarted by the sentryd process.
Recovery
No action required. Any active LSMS GUI processes will automatically reconnect.
Event Details
Table 74. Event 6009 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RECOV: <NPAC_region_ID> agent
Source
Active server
Frequency
Trap
Trap ID
79
Trap MIB Name
NPACagentForRegionRestarted
6010
Explanation
The sentryd process was unable to restart the npacagent process for the region specified by <NPAC_region_ID>.
Recovery
Event Details
Table 75. Event 6010 Details
GUI Notification
Severity
Critical
Text
Failure Restarting NPACagent [<NPAC_region_ID>]
Text
Notify:Sys Admin - RFAILD: <NPAC_region_ID> agent
Source
Active server
Frequency
Trap
Trap ID
80
Trap MIB Name
failureToRestartNPACagentRegion
6020
Explanation
The npacagent process has been stopped due to a fault in accessing the regional database.
Recovery
A database error has occurred. Contact the My Oracle Support (MOS).
Event Details
Table 76. Event 6020 Details
GUI Notification
Severity
Critical
Text
NPACagent Has Been Shut Down - Database Access Error
Text
Notify:Sys Admin - <NPAC_region_ID> DB error
Source
Active server
Frequency
Trap
Trap ID
189
Trap MIB Name
NPACagentStopRegDBaccessFault
8000
Explanation
The LSMS Surveillance feature is in operation.
Recovery
Event Details
Table 77. Event 8000 Details
GUI Notification
Severity
None
Text
Text
Keep alive
Source
Frequency
Trap
Trap ID
19
Trap MIB Name
survFeatureOn
8001
Explanation
The network element resynchronization database contains more than 1 million entries.
Recovery
Each day, as part of a cron job, the LSMS trims the resynchronization database so that it contains 768,000 entries. The occurrence of this event means that more than 232,000 transactions have been received since the last cron job. If this event occurs early in the day, contact the My Oracle Support (MOS).
Event Details
Table 78. Event 8001 Details
GUI Notification
Severity
Major
Text
ResyncDB Contains 1 Mil Entries
Text
Notify:Sys Admin - ResyncDB 1 Mil
Source
Active server
Frequency
Once
Trap
Trap ID
34
Trap MIB Name
resynchLogMidFull
8003
Explanation
The pending queue, used to hold the transactions to send to the network element (which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text), is over half full.
Recovery
No recovery is required. Informational only.
Event Details
Table 79. Event 8003 Details
GUI Notification
Severity
Major
Text
EMS Pending Queue Is Half full
Text
Notify:Sys Admin - CLLI=<CLLI>
Source
Active server
Frequency
Trap
Trap ID
43
Trap MIB Name
ensPendingQueueHalfFull
8004
Explanation
The pending queue, used to hold the transactions to send to the network element (which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text), is completely full. The association to that EMS will be broken.
Recovery
No manual recovery required. The LSMS will automatically re-establish the association to the EMS and synchronization will take place.
Event Details
Table 80. Event 8004 Details
GUI Notification
Severity
Critical
Text
EMS Pending Queue Is Full
Text
Source
Active server
Frequency
Trap
Trap ID
44
Trap MIB Name
emsPendingQueueMaxReached
8005
Explanation
There was a data error in a record that prevented the LSMS eagleagent from sending the record to the network element.
Recovery
Both the error and the ignored record are written to the file /var/TKLC/lsms/logs/trace/LsmsTrace.log.<mmdd>, where <mmdd> indicates the month and day the error occurred. Examine the log file for the month and day this error was reported to determine what the error was. Enter the data manually or send it again.
Event Details
Table 81. Event 8005 Details
GUI Notification
Severity
Minor
Text
Eagleagent <CLLI> Ignoring Record: <DataError>
Text
None
Source
Frequency
Trap
Trap ID
84
Trap MIB Name
eagleAgentIgnoredRecord
8024
Explanation
The Service Assurance agent has started successfully.
Recovery
Event Details
Table 82. Event 8024 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin
Source
Active server
Frequency
Trap
Trap ID
67
Trap MIB Name
serviceAssuranceAgentStarted
8025
Explanation
Association with the Service Assurance Manager, identified by <Service_Assurance_Manager_Name>, has been established successfully.
Recovery
Event Details
Table 83. Event 8025 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - <Service_Assurance_Manager_Name>
Source
Active server
Frequency
Trap
Trap ID
68
Trap MIB Name
establishServAssuranceMgrAssoc
8026
Explanation
Association with the Service Assurance Manager, identified by <Service_Assurance_Manager_Name>, has been stopped or disconnected.
Recovery
Contact the Service Assurance system administrator to determine the cause of disconnection, then have Service Assurance system administrator reassociate the Service Assurance Manager to the Service Assurance Agent.
Event Details
Table 84. Event 8026 Details
GUI Notification
Severity
None
Text
Text
Source
Active server
Frequency
Trap
Trap ID
69
Trap MIB Name
servAssuranceMgrAssocBroken
8027
Explanation
The Service Assurance agent is not currently running.
Recovery
No action required; the Service Assurance agent should be restarted automatically.
Event Details
Table 85. Event 8027 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin
Source
Active server
Frequency
Trap
Trap ID
70
Trap MIB Name
servAssuranceAgentNotRunning
8037
Explanation
The OSI process has failed. The sentryd process will attempt to restart.
Recovery
No action required; the sentryd process will attempt to restart the failed process.
Event Details
Table 86. Event 8037 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - FAILD: OSI
Source
Active server
Frequency
Trap
Trap ID
88
Trap MIB Name
osiDaemonFailure
8038
Explanation
The OSI process has been successfully restarted by the sentryd process.
Recovery
No action required. The sentryd process will attempt to restart the npacagent processes for all active regions. Any active LSMS GUI processes will automatically reconnect.
Event Details
Table 87. Event 8038 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RECOV: OSI
Source
Active server
Frequency
Trap
Trap ID
89
Trap MIB Name
osiDaemonRestarted
8039
Explanation
The sentryd process was not able to restart the OSI process.
Recovery
Event Details
Table 88. Event 8039 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RFAILD: OSI
Source
Active server
Frequency
Trap
Trap ID
90
Trap MIB Name
osiDaemonRestartFailure
8040
Explanation
The Surveillance feature has detected that the sentryd process is no longer running.
Recovery
No action required; the LSMS HA software will attempt to restart the sentryd process.
Event Details
Table 89. Event 8040 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - FAILD: sentryd
Source
Active server
Frequency
Trap
Trap ID
91
Trap MIB Name
sentrydFailure
8049
Explanation
The EMS/NE has rejected the NPANXX GTT creation, deletion, or modification transaction, and the NPANXX value in the transaction could not be determined.
Recovery
Look in the transaction log file, /var/TKLC/lsms/logs/<CLLI>/LsmsTrans.log.MMDD, and locate the NE’s response to the NPANXX GTT command to determine why the command failed. Re-enter the NPANXX GTT data correctly, which will cause the LSMS to try to command again.
Event Details
Table 90. Event 8049 Details
GUI Notification
Severity
Major
Text
<CLLI>: NPANXX GTT <type_of_operation> Failed
Text
None
Source
Frequency
Trap
Trap ID
126
Trap MIB Name
npanxxGTTValueNotFound
8050
Explanation
The EMS/NE has rejected the NPANXX GTT creation, deletion, or modification transaction for the specified NPANXX value.
Recovery
Event Details
Table 91. Event 8050 Details
GUI Notification
Severity
Major
Text
<CLLI>: NPANXX GTT <type_of_operation> Failed for NPANXX <NPANXX_value>
Text
None
Source
Frequency
Trap
Trap ID
127
Trap MIB Name
npanxxGTTValueRejected
8051
Explanation
The EMS/NE has rejected the Override GTT creation, deletion, or modification transaction, and the LRN value in the transaction could not be determined.
Recovery
Look in the transaction log file, /var/TKLC/lsms/logs/<CLLI>/LsmsTrans.log.MMDD, and locate the NE’s response to the Override GTT command to determine why the command failed. Re-enter the Override GTT data correctly, which will cause the LSMS to try to command again.
Event Details
Table 92. Event 8051 Details
GUI Notification
Severity
Major
Text
<CLLI>: Override GTT <type_of_operation> Failed
Text
None
Source
Frequency
Trap
Trap ID
128
Trap MIB Name
overrideGTTValueNotFound
8052
Explanation
The EMS/NE has rejected the Override GTT creation, deletion, or modification transaction for the specified LRN value.
Recovery
Event Details
Table 93. Event 8052 Details
GUI Notification
Severity
Major
Text
<CLLI>: Override GTT <type_of_operation> Failed for LRN <LRN_value>
Text
None
Source
Frequency
Trap
Trap ID
129
Trap MIB Name
overrideGTTValueRejected
8053
Explanation
The LSMS was not able to complete the automatic synchronization with the EMS/NE. Possible reasons include:
Recovery
Verify the connection between the LSMS and the EMS; then reinitialize the MPS. If this notification appears again, perform one of the bulk download procedures in the LNP Database Synchronization User's Guide.
Event Details
Table 94. Event 8053 Details
GUI Notification
Severity
Major
Text
Short Synchronization Failed
Text
None
Source
Frequency
Trap
Trap ID
131
Trap MIB Name
unableToCompleteAutoResynch
8054
Explanation
The LSMS has started its automatic synchronization with the EMS/NE.
Recovery
Event Details
Table 95. Event 8054 Details
GUI Notification
Severity
Major
Text
Short Synchronization Started
Text
None
Source
Frequency
Trap
Trap ID
132
Trap MIB Name
autoResynchNEStarted
8055
Explanation
The automatic resynchronization of databases after an outage between the LSMS and the NPAC has completed successfully.
Recovery
Event Details
Table 96. Event 8055 Details
GUI Notification
Severity
Cleared
Text
Recovery Complete
Text
None
Source
Frequency
Trap
Trap ID
133
Trap MIB Name
dbResynchCompleted
8059
Explanation
The LSMS has completed its automatic synchronization with the EMS/NE.
Recovery
Event Details
Table 97. Event 8059 Details
GUI Notification
Severity
Cleared
Text
Short Synchronization Complete
Text
None
Source
Frequency
Trap
Trap ID
138
Trap MIB Name
emsShortSynchCompleted
8060
Explanation
The EMS pending queue used to hold the transactions to send to the EMS/NE identified by <CLLI> in the Survellance notification, has fallen sufficiently below the halfway full point.
Recovery
Event Details
Table 98. Event 8060 Details
GUI Notification
Severity
Cleared
Text
EMS Pending Queue Less Than Half Full
Text
Source
Active server
Frequency
Trap
Trap ID
141
Trap MIB Name
pendingQueueHalfFull
8061
Explanation
The EMS pending queue used to hold the transactions to send to the EMS/NE identified by <CLLI> in the Survellance notification, has fallen sufficiently below the full point.
Recovery
Event Details
Table 99. Event 8061 Details
GUI Notification
Severity
Cleared
Text
EMS Pending Queue No Longer Full
Text
Source
Active server
Frequency
Trap
Trap ID
142
Trap MIB Name
pendingQueueNotFull
8064
Explanation
The specified NPA-NXX is opened for portability starting at the value of the <EffectiveTimestamp> field.
Recovery
Event Details
Table 100. Event 8064 Details
GUI Notification
Severity
Event
Text
New NPA-NXX: SPID [<SPID>], NPANXX [<NPANXX>], TS [<EffectiveTimestamp>]
Text
None
Source
Frequency
Trap
Trap ID
145
Trap MIB Name
npaNxxOpenedForPortabilityAtTS
8065
Explanation
The first telephone number in the specified NPA-NXX is ported starting at the value of the <EffectiveTimestamp> field.
Recovery
Event Details
Table 101. Event 8065 Details
GUI Notification
Severity
Event
Text
First use of NPA-NXX: SPID [<SPID>], NPANXX [<NPANXX>], TS [<EffectiveTimestamp>]
Text
None
Source
Frequency
Trap
Trap ID
146
Trap MIB Name
npaNxxPortedAtTS
8066
Explanation
An audit of the network element identified by <CLLI> has begun.
Recovery
Event Details
Table 102. Event 8066 Details
GUI Notification
Severity
Cleared
Text
Audit LNP DB Synchronization Started
Text
NE <CLLI> Audit started
Source
Active server
Frequency
Trap
Trap ID
147
Trap MIB Name
ebdaAuditActive
8067
Explanation
An audit of the network element identified by <CLLI> has completed successfully.
Recovery
Event Details
Table 103. Event 8067 Details
GUI Notification
Severity
Cleared
Text
Audit LNP DB Synchronization Completed
Text
NE <CLLI> Audit completed
Source
Active server
Frequency
Trap
Trap ID
148
Trap MIB Name
ebdaAuditSuccess
8068
Explanation
An audit of the network element identified by <CLLI> has failed.
Recovery
Inspect the log file /var/TKLC/lsms/logs/<CLLI>/LsmsTrans.log.MMDD for details as to the cause of the error. After clearing the cause of the error, start the audit again.
Event Details
Table 104. Event 8068 Details
GUI Notification
Severity
Critical
Text
Audit LNP DB Synchronization Failed
Text
NE <CLLI> Audit failed
Source
Active server
Frequency
Trap
Trap ID
149
Trap MIB Name
ebdaAuditFailure
8069
Explanation
The user aborted an audit of the network element identified by <CLLI> before it had completed.
Recovery
Event Details
Table 105. Event 8069 Details
GUI Notification
Severity
Cleared
Text
Audit LNP DB Synchronization Aborted
Text
NE <CLLI> Audit aborted
Source
Active server
Frequency
Trap
Trap ID
150
Trap MIB Name
ebdaAuditAbortedByUser
8070
Explanation
A reconcile has started at the completion of an audit.
Recovery
Event Details
Table 106. Event 8070 Details
GUI Notification
Severity
Cleared
Text
Reconcile LNP DB Synchronization Started
Text
NE <CLLI> Reconcile started
Source
Active server
Frequency
Trap
Trap ID
151
Trap MIB Name
ebdaReconcileActive
8071
Explanation
A reconcile, which was performed at the end of an audit, has completed.
Recovery
Event Details
Table 107. Event 8071 Details
GUI Notification
Severity
Cleared
Text
Reconcile LNP DB Synchronization Complete
Text
NE <CLLI> Reconcile completed
Source
Active server
Frequency
Trap
Trap ID
152
Trap MIB Name
ebdaReconcileSuccess
8072
Explanation
A reconcile, which was performed at the end of an audit, has failed before it completed.
Recovery
Inspect the log file /var/TKLC/lsms/logs/<CLLI>/LsmsAudit.log.MMDD for details as to the cause of the error. After clearing the cause of the error, start the reconcile again.
Event Details
Table 108. Event 8072 Details
GUI Notification
Severity
Critical
Text
Reconcile LNP DB Synchronization Failed
Text
NE <CLLI> Reconcile failed
Source
Active server
Frequency
Trap
Trap ID
153
Trap MIB Name
ebdaReconcileFailure
8073
Explanation
The user has stopped a reconcile before it completed.
Recovery
Event Details
Table 109. Event 8073 Details
GUI Notification
Severity
Cleared
Text
Reconcile LNP DB Synchronization Aborted
Text
NE <CLLI> Reconcile aborted
Source
Active server
Frequency
Trap
Trap ID
154
Trap MIB Name
ebdaReconcileAbortedByUser
8078
Explanation
A bulk download is currently running.
Recovery
Event Details
Table 110. Event 8078 Details
GUI Notification
Severity
Cleared
Text
Bulk Load LNP DB Synchronization Started
Text
NE <CLLI> Bulk load started
Source
Active server
Frequency
Trap
Trap ID
159
Trap MIB Name
ebdaBulkLoadActive
8079
Explanation
A bulk download has completed successfully.
Recovery
Event Details
Table 111. Event 8079 Details
GUI Notification
Severity
Cleared
Text
Bulk Load LNP DB Synchronization Complete
Text
NE <CLLI> Bulk load completed
Source
Active server
Frequency
Trap
Trap ID
160
Trap MIB Name
ebdaBulkLoadSuccess
8080
Explanation
A bulk download has failed before it completed.
Recovery
Inspect the log file /var/TKLC/lsms/logs/<CLLI>/LsmsBulkLoad.log.MMDD for details as to the cause of the error. After clearing the cause of the error, start the bulk download again.
Event Details
Table 112. Event 8080 Details
GUI Notification
Severity
Critical
Text
Bulk Load LNP DB Synchronization Failed
Text
NE <CLLI> Bulk load failed
Source
Active server
Frequency
Trap
Trap ID
161
Trap MIB Name
ebdaBulkLoadFailure
8081
Explanation
The user has stopped a bulk download before it completed.
Recovery
Event Details
Table 113. Event 8081 Details
GUI Notification
Severity
Cleared
Text
Bulk Load LNP DB Synchronization Aborted
Text
NE <CLLI> Bulk load aborted
Source
Active server
Frequency
Trap
Trap ID
162
Trap MIB Name
ebdaBulkLoadAbortedByUser
8082
Explanation
A user-initiated resynchronization is currently running.
Recovery
Event Details
Table 114. Event 8082 Details
GUI Notification
Severity
Cleared
Text
Re-sync LNP DB Synchronization Started
Text
NE <CLLI> Re-sync started
Source
Active server
Frequency
Trap
Trap ID
163
Trap MIB Name
ebdaResyncActive
8083
Explanation
A user-initiated resynchronization has completed successfully.
Recovery
Event Details
Table 115. Event 8083 Details
GUI Notification
Severity
Cleared
Text
Re-sync LNP DB Synchronization Complete
Text
NE <CLLI> Re-sync completed
Source
Active server
Frequency
Trap
Trap ID
164
Trap MIB Name
ebdaResyncSuccess
8084
Explanation
A user-initiated resynchronization has failed before it completed.
Recovery
Inspect the contents of the file /var/TKLC/lsms/logs/<CLLI>/LsmsResync.log.MMDD to determine the cause of the error. After clearing the cause of the error, start the user-initiated resynchronization again.
Event Details
Table 116. Event 8084 Details
GUI Notification
Severity
Critical
Text
Re-sync LNP DB Synchronization Failed
Text
NE <CLLI> Re-sync failed
Source
Active server
Frequency
Trap
Trap ID
165
Trap MIB Name
ebdaResyncFailure
8085
Explanation
The user has stopped a user-initiated resynchronization before it completed.
Recovery
Event Details
Table 117. Event 8085 Details
GUI Notification
Severity
Cleared
Text
Re-sync LNP DB Synchronization Aborted
Text
NE <CLLI> Re-sync aborted
Source
Active server
Frequency
Trap
Trap ID
166
Trap MIB Name
ebdaResyncAbortedByUser
8088
Explanation
A scheduled file transfer has failed.
Recovery
Inspect the error log file/var/TKLC/lsms/logs/aft/aft.log.MMDD for details as to the cause of the error.
Event Details
Table 118. Event 8088 Details
GUI Notification
Severity
Major
Text
Automatic File Transfer Failure - See Log for Details
Text
Notify:Sys Admin- Auto xfer Failure
Source
Active server
Frequency
Trap
Trap ID
171
Trap MIB Name
automaticFileTransferFeatureFailure
8089
Explanation
An NPA-NXX split activation completed successfully.
Recovery
Event Details
Table 119. Event 8089 Details
GUI Notification
Severity
Cleared
Text
Activate Split Successful OldNPA=<old_NPA> NewNPA=<new_NPA> NXX=<NXX>
Text
None
Source
Frequency
Trap
Trap ID
10
Trap MIB Name
npaSplitActOk
8090
Explanation
An NPA-NXX split activation failed.
Recovery
Perform and audit and reconcile of NPA Split information at the network element.
Event Details
Table 120. Event 8090 Details
GUI Notification
Severity
Critical
Text
Activate Split Failed OldNPA=<old_NPA> NewNPA=<new_NPA> NXX=<NXX>
Surveillance Notification
Text
None
Source
Frequency
Trap
Trap ID
172
Trap MIB Name
npaSplitActFailed
8091
Explanation
At least one active NPA-NXX split is past its end date and needs to be deleted.
Recovery
Do the following:
  1. View all split objects (for information, refer to the Database Administrator's Guide) to determine which objects have end dates that have already passed.
  2. Delete the objects whose end dates have passed (for information, refer to the Database Administrator's Guide).
Event Details
Table 121. Event 8091 Details
GUI Notification
Severity
Major
Text
Active Splits Are Past Their End Dates
Text
None
Source
Frequency
Trap
Trap ID
173
Trap MIB Name
activeSplitsPastEndDates
8096
Explanation
The EMS/NE has rejected the NPANXX Split operation indicated by <operation>, and the NPANXX value in the transaction could not be determined.
Recovery
Look in the transaction log file, /var/TKLC/lsms/logs/<CLLI>/LsmsTrans.log.MMDD, and locate the NE’s response to the NPANXX Split command to determine why the command failed. Delete and re-enter the NPANXX Split data correctly, which will cause the LSMS to try to command again.
Event Details
Table 122. Event 8096 Details
GUI Notification
Severity
Major
Text
<CLLI>: NPANXX Split <operation> Failed
Text
None
Source
Frequency
Trap
Trap ID
178
Trap MIB Name
EmsNeRejNpaNxxSplitNotDetermined
8097
Explanation
The EMS/NE has rejected the NPANXX Split operation indicated by <operation> for the indicated NPANXX value.
Recovery
Event Details
Table 123. Event 8097 Details
GUI Notification
Severity
Major
Text
<CLLI>: NPANXX Split <operation> Failed for New NPANXX <NPANXX>
Text
None
Source
Frequency
Trap
Trap ID
179
Trap MIB Name
EmsNeRejectedNpaNxxSplit
8098
Explanation
The LSMS is not able to confirm the physical connectivity with the directly connected query server identified by <hostname>. The problem may be one of the following:
Recovery
Event Details
Table 124. Event 8098 Details
GUI Notification
Severity
Major
Text
Query Server <hostname> Physical Connection Lost
Text
Query Server=<hostname> Physical Conn Lost
Source
Active Server
Frequency
As soon as condition occurs, and at five-minute intervals as long as condition exists
SNMP Trap
Trap ID
180
Trap MIB Name
physicalConnectivityWithQueryServerLost
8099
Explanation
The query server identified by <hostname> does not have a replication connection established with the LSMS. The problem may be one of the following:
Recovery
  1. At the query server, perform the following substeps:
    1. Start the MySQL command line utility on the slave server:
      # cd /opt/mysql/mysql/bin
      # mysql -u root -p
      Enter password:
      <Query Server/s MySql root user password>
    2. Determine whether the query server is running by entering the following command and looking at the Slave_IO_Running and Slave_SQL_Running column values.
      mysql> SHOW SLAVE STATUS \G;
      • If the Slave_IO_Running and Slave_SQL_Running column values show that the slave is not running, verify the query server's /usr/mysql1/my.cnf option file (refer to “MySQL Replication Configuration for Query Servers,” in Appendix A, “Configuring the Query Server,” of the Configuration Guide) and check the error log (/usr/mysql1/<hostname>.err) for messages.
      • If the Slave_IO_Running and Slave_SQL_Running column values show that the slave (query server) is running, enter the following command to verify whether the slave established a connection with the master (LSMS or another query server acting as a master/slave).
        mysql> SHOW PROCESSLIST;
        Find the thread with the system user value in the User column and none in the Host column, and check the State column. If the State column says “connecting to master,” verify that the master hostname is correct, that the DNS is properly set up, whether the master is actually running, and whether it is reachable from the slave (refer to Appendix A, “Configuring the Query Server,” of the Configuration Guide for information about port configuration for firewall protocol filtering if the master and slave are connecting through a firewall).
      • If the slave was running, but then stopped, enter the following command:
        mysql> SHOW SLAVE STATUS;
        Look at the output. This error can happen when some query that succeeded on the master fails on the slave, but this situation should never happen while the replication is active if you have taken a proper snapshot of the master and never modify the data on the slave outside of the slave thread.
  2. However, if this is not the case, or if the failed items are not needed and there are only a few of them, try the following:
    1. First see if there is some stray record in the way on the query server. Understand how it got there, then delete it from the query server database and run start slave.
    2. If the above does not work or does not apply, try to understand if it would be safe to make the update manually (if needed) and then ignore the next query from the LSMS.
    3. If you have decided you can skip the next query, enter one of the following command sequences:
      • To skip a query that uses AUTO_INCREMENT or LAST_INSERT_ID(), enter:
        mysql> SET GLOBAL SQL_SLAVE_SKIP_COUNTER=2;
        mysql> start slave;
        Queries that use AUTO_INCREMENT or LAST_INSERT_ID() take two events in the binary log of the master.
      • Otherwise, enter:
        mysql> SET GLOBAL SQL_SLAVE_SKIP_COUNTER=1;
        mysql> start slave;
  3. If you are sure the query server database started out perfectly in sync with the LSMS database, and no one has updated the tables involved outside of the slave thread, contact the My Oracle Support (MOS) so you will not have to do the above steps again.
  4. If all else fails, read the error log, /usr/mysql/<hostname>.err. If the log is big, run the following command on the slave:
    grep -i slave /usr/mysql1/<hostname>.err
    (There is no generic pattern to search for on the master, as the only errors it logs are general system errors. If it can, the master will send the error to the slave when things go wrong.)
    • If the error log on the slave conveys that it could not find a binary log file, this indicates that the binary log files on the master have been removed (purged). Binary logs are periodically purged from the master to prevent them from growing unbounded and consuming large amounts of disk resources. However, if a query server was not replicating and one of the binary log files it wants to read is purged, it will be unable to replicate once it comes up. If this occurs, the query server is required to be reset with another snapshot of data from the master or another query server (see “Reload a Query Server Database from the LSMS” and “Reload a Query Server Database from Another Query Server”).
    • When you have determined that there is no user error involved, and replication still either does not work at all or is unstable, please contact the My Oracle Support (MOS).
Event Details
Table 125. Event 8099 Details
GUI Notification
Severity
Major
Text
Query Server <hostname> Replication Connection Lost
Text
Query Server=<hostname> Replication Conn Lost
Source
Active Server
Frequency
SNMP Trap
Trap ID
181
Trap MIB Name
queryServerConnectionWithLsmsLost
8100
Explanation
The SV/NPB storage database has exceeded the configured percent usage threshhold.
Recovery
Event Details
Table 126. Event 8100 Details
GUI Notification
Severity
Event
Text
SV/NPB Storage Exceeds <%> percent
Text
Notify:Sys Admin - SV/NPB threshold %
Source
Both servers
Frequency
Every 5 minutes after condition occurs
Trap
Trap ID
194
Trap MIB Name
svNpbPercentUsage
8101
Explanation
This event indicates that the SV/NPB storage database usage is below the configured percent usage threshold.
Recovery
Event Details
Table 127. Event 8101 Details
GUI Notification
Severity
Cleared
Text
SV/NPB storage falls below <%> percent
Text
Notify: Sys Admin - SV/NPB cleared
Source
Both servers
Frequency
Trap
Trap ID
207
Trap MIB Name
svNpbBelowLimit
8102
Explanation
The event number present in the untilClear filter list is cleared. The event number is removed from the untilClear filter list.
Recovery
Event Details
Table 128. Event 8102 Details
GUI Notification
Severity
Event
Text
<Event number> in the untilClear filter list, event clear received at <%s>
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8103
Explanation
The alarm filter counter has reached its limit; the counter will start again from one.
Recovery
Event Details
Table 129. Event 8103 Details
GUI Notification
Severity
Event
Text
Counter associated with event <event number> exceeds limit <%s>. Resetting counter.
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8104
Explanation
The event number present in the untilTimeout filter list is cleared. The event number is removed from the untilTimeout filter list.
Recovery
Event Details
Table 130. Event 8104 Details
GUI Notification
Severity
Event
Text
<Event number> in the untilTimeout filter list, event timeout at <%s>
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8105
Explanation
The log capture started by the user has failed.
Recovery
Event Details
Table 131. Event 8105 Details
GUI Notification
Severity
Minor
Text
Logs Capture Failed
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8106
Explanation
The MySQL Port has been updated. The LSMS application must be restarted.
Recovery
The application must be restarted. Restart the LSMS application first on the active server and then on the standby server. For more information, refer to the Configuration Guide.
Event Details
Table 132. Event 8106 Details
GUI Notification
Severity
Event
Text
MySQL Port changed from <%s> to <%s>. LSMS application restart required.
Text
Notify: Sys Admin - LSMS restart required
Source
Active server
Frequency
Trap
Trap ID
208
Trap MIB Name
mysqlPortUpdated
8107
Explanation
The MySQL Port has been updated. The Query Server configuration needs to be updated with the new MySQL port.
Recovery
Configure the Query Server with the updated MySQL port. For more information, refer to the Configuration Guide.
Event Details
Table 133. Event 8107 Details
GUI Notification
Severity
Event
Text
MySQL Port changed from <%s> to <%s>. Query Server configuration updated required.
Text
Notify: Sys Admin - QS updated required
Source
Active server
Frequency
Trap
Trap ID
209
Trap MIB Name
queryServerResetConfiguration
8108
Explanation
At least one of the connected Query Servers is out of sync, and the binary logs cannot be purged without user confirmation.
Recovery
When the Query Server is out of sync, automatic purging is not possible. To delete all but the last 10 binary logs, log on to the active LSMS server as root and enter the following command:
pruneBinaryLogs -force
Event Details
Table 134. Event 8108 Details
GUI Notification
Severity
Minor
Text
Automatic purging of binary logs cannot be done. User confirmation required.
Text
Notify: Sys Admin - Purge need confirmation
Source
Both servers
Frequency
Every 45 minutes
Trap
Trap ID
210
Trap MIB Name
purgeConfirmRequired
8109
Explanation
Disk usage is reaching the capacity threshold, and an automatic purge of binary logs is imminent.
Recovery
Event Details
Table 135. Event 8109 Details
GUI Notification
Severity
Minor
Text
Disk usage reaching <%> percent. Purging of binary logs is imminent.
Text
Notify: Sys Admin - Purging is imminent
Source
Both servers
Frequency
Every 45 minutes
Trap
Trap ID
211
Trap MIB Name
purgeImminent
8110
Explanation
Logs capture has been started by the user.
Recovery
Event Details
Table 136. Event 8110 Details
GUI Notification
Severity
Cleared
Text
Logs Capture Started
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8111
Explanation
The logs capture started by the user completed successfully.
Recovery
Event Details
Table 137. Event 8111 Details
GUI Notification
Severity
Minor
Text
Logs Captured Successfully
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8112
Explanation
Syscheck was not able to restart automatically by the cron job.
Recovery
Event Details
Table 138. Event 8112 Details
GUI Notification
Severity
Event
Text
Failed to restart syscheck services
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8116
Explanation
The HTTP protocol is enabled but secure HTTP (HTTPS) is recommended.
Recovery
For information on configuring the protocols, see Starting an Web-Based LSMS GUI Session.
Event Details
Table 139. Event 8116 Details
GUI Notification
Severity
Event
Text
HTTP is enabled and it is recommended to use HTTPS.
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8117
Explanation
HTTP is disabled and HTTPS is enabled.
Recovery
No recovery required; only HTTPS is enabled now.
Event Details
Table 140. Event 8117 Details
GUI Notification
Severity
Event
Text
Only HTTPS is enabled now.
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8118
Explanation
Both HTTP and HTTPS are enabled, but using only HTTPS is recommended.
Recovery
Event Details
Table 141. Event 8118 Details
GUI Notification
Severity
Event
Text
Both HTTP and HTTPS are enabled and it is recommended to use HTTPS.
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
Additional Trap Information
Trap Id Trap MIB Name Notification Description Trap variables def Retry Interval Severity Event Num GUI Event Text
Pair
Event
Num
25 dataReplInfo This notification indicates that database replication is delayed. eventNbr = Oracle specific unique identifier for event notification. This eventNbr field can be used to reference Oracle documentation. dbReplInfo = Info message from database replication. Every 5 mins event_notif_event 4011 DB Repl Info - %s 0
201 snapInvalidErr This notification indicates that the Invalid Snapshot has been detected. eventNbr = Oracle specific unique identifier for event notification. This eventNbr field can be used to reference Oracle documentation. snapName = Name of the invalid snapshot. Every 30 mins event_notif_critical 4034 Invalid Snapshot - %s 4035
203 snapFullErr This notification indicates that the Snapshot is greater than 80% full. eventNbr = Oracle specific unique identifier for event notification. This eventNbr field can be used to reference Oracle documentation. snapName = Name of the invalid/hanging snapshot. Every 30 mins event_notif_critical 4036 Full Snapshot - %s 4037
Trap Id Trap MIB Name Notification Description Frequency Source Clearing behavior
212 resyncStartTrap The trap is sent by the LSMS to NMS when the LSMS is about to start resynchronization Every time when starting a resynchronization with a NMS /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
213 resyncStopTrap The trap is sent by the LSMS to NMS when resynchronization is complete Every time when a resynchronization with a NMS is complete /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
214 resyncRejectTrap The trap is sent by the LSMS to NMS when a resynchronization request is rejected by LSMS Every time when a resynchronization request is initialized while an existing resynchronization is still being processed /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
215 resyncRequiredTrap The trap is sent by the LSMS to NMS when the LSMS is rebooted or LSMS is started Every time when LSM S is rebooted or restarted /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
216 heartBeatTrap The trap is sent by the LSMS to NMS periodically to indicate that the LSMS is up Per the configured value in second (0, 5-7200), where 0 indicates the heartbeat trap is disabled. /vobs/lsms/apps/snmp/ lsmsSnmpHeartbeatSender.pl None
217 lsmsAlarmTrapV3 The trap will indicate that the following information is for a particular event Every v3 trap message sent to nms will carry this OID /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
218 resyncErrCode errorCode = 0, Resynchronization completed successfully. errorCode = 1, Resynchronization aborted by NMS. errorCode = 2, Resynchronization already in progress for the NMS. errorCode = 3, Resynchronization Aborted, Database error occurred. errorCode = 4, Resynchronization not in progress. Every time when either resyncStopTrap or resyncRejectTrap sent to NMS /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
