Kill <index> Command
The kill <index> command terminates a session on the server. The following example uses the “show users” command to display the index number to use with the kill <index> command.
ACMEPACKET# show users
Index task-id remote-address IdNum duration type state User
0 0x33a4c394 0 00:01:20 console user * console
31 NA 10.1.20.14:51218 31 00:00:55 http user user
32 NA 10.1.20.14:443 32 00:00:29 https user user
ACMEPACKET# kill 31
The kill 31 command terminates the Web server session number 31.
After setting the Web server configuration, you can view the stored monitored data from the Oracle® Enterprise Session Border Controller (E-SBC) using the GUI through an Internet browser. For more information about the GUI, see Configuring TLS on the Web Server.
