Show users Command
The show users command displays information about users currently logged into a session on the server. Each user is indicated by an index number. The following is an example of the show users command output.
The index number for Web sessions always begins at 31.ACMEPACKET# show users
Index task-id remote-address IdNum duration type state User
0 0x33a4c394 0 00:01:20 console user * console
31 NA 10.1.20.14:51218 31 00:00:55 http user user
32 NA 10.1.20.14:443 32 00:00:29 https user user
The following table describes each column in the above output.
| Column Heading | Description |
| Index | Number that the server assigns to the user as an identification of that user.
Note: The index for Web sessions always begins at index 31. |
| Task-id | Alpha-numeric number that the server assigns to the task currently being performed. This is the session ID assigned to the task at log-in time. This field is not applicable to the Web server. |
| Remote-address | IP address and port number for which the server is connected. |
| IdNum | Identification number of the user currently logged into the server. This number is the same as the Index number. |
| Duration | Amount of time, in hours, minutes, and seconds, that the user has currently been logged into a session on the server. Format is HH:MM:SS. |
| Type | Type of service that the user is currently using for connection to the server. Valid values can be:
Console User is connected to the server via a local console. HTTP User is connected to the server using a Web HTTP service. HTTPS User is connected to the server using a secure Web HTTPS service. |
| State | Current state of the connection on the server. Valid values are:
admin user Note: An “*’ indicates a current connection. |
| User | Current user type logged into the server. Valid values are:
console user admin |
