PreviousNextJavaScript must be enabled to correctly display this content
System Setup
Before you begin configuring the
Oracle® Enterprise Session Border Controller, you will set the product type with the
setup product command, and the features with the
setup entitlements command.
Not all of the features are available on all platforms.
