Setup Product
  1. Type setup product at the ACLI. If this is the first time running the command on this hardware, the product will show as Uninitialized.
  2. Type 1 <Enter> to modify the uninitialized product.
  3. Type the number followed by <Enter> for the product type you wish to initialize.
  4. Type s <Enter> to commit your choice as the product type of this platform.
  5. Reboot your Oracle® Enterprise Session Border Controller.
When configuring an HA pair, you must provision the same product type and features on each system.
