Setup Entitlements
- Type setup entitlements at the ACLI. Currently provisioned features are printed on the screen.
- Type the number of the feature you wish to setup followed by pressing the <Enter> Key. Some features are set as enabled/disabled (provisionable features), and some features are provisioned with a maximum capacity value (provisionable capacity features). The command will let you provision these values as appropriate.
- Type enabled or disabled to set a provisionable feature, or type an integer value for a provisionable capacity feature. Both input types are followed by pressing the <Enter> key.
- Repeat steps 2 and 3 to setup additional entitlements.
- Type d followed by the <Enter> key to review the full range of your choices. Note that disabled entitlements display their state as blank.
- Type s followed by the <Enter> key to commit your choice as an entitlement for your system. After saving the value succeeds you will be returned to the ACLI.
- Reboot your Oracle® Enterprise Session Border Controller.
