PreviousNextJavaScript must be enabled to correctly display this content
Export an E-SBC Configuration to a CSV File
You can export an existing configuration from the
Oracle® Enterprise Session Border Controller (E-SBC ) to a CSV file that you name, using the following command:
spl save acli config-csv <filename>
The
E-SBC saves the configuration in the /var directory.
