Import a CSV Configuration File
After you create a CSV file that contains the Oracle® Enterprise Session Border Controller (E-SBC) configuration, you can import the file into the E-SBC using the spl load acli config-csv command.
The
spl load acli config-csv command loads the CSV file from the volatile file system (/var), into the editing configuration of the
E-SBC.
spl load acli config-csv <filename>
