Codec Policy
To configure a codec policy to support DTMF audio tones, as transcoded:
In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
Type media-manager and press Enter.
configure# media-manager -
Type
codec-policy and press Enter.
ORACLE(media-manager)# codec-policy ORACLE(codec-policy)#
If you are adding support for this feature to a pre-existing configuration, then you must select the specific configuration instance, using the ACLI
select command.
ORACLE(codec-policy)# select <name>: 1: private 2: public selection:1 ORACLE(codec-policy)#
dtmf-in-audio—Set this parameter to
disabled,
preferred, or
dual based upon how the
Oracle® Enterprise Session Border Controller should support the conversion of signaling messages or RFC 2833 to DTMF Audio tones in the realm where this codec policy is active.
disabled—does not support DTMF audio tones as transcoded in this realm.
preferred—supports DTMF audio tones as transcoded in this realm.
dual—supports both transcoded DTMF audio tones and signaling-based DTMF indications if possible.
- Save and activate your configuration.
