Translate Non2833 Event Behavior
To configure the exceptional behavior:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the media-level configuration elements.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
media-manager and press Enter to begin configuring this feature.
ORACLE(media-manager)# media-manager ORACLE(media-manager-config)#
- translate-non-rfc2833-event—Set this parameter to enabled to use non-default behavior described in Override Preferred RFC 2833.
- translate-non-inband-event—Set this parameter to enabled to use non-default behavior described in Override Preferred DTMF Audio.
- Save and activate your configuration.
