70007 - Node isolated - All links down
- Alarm Group
- vSTP
- Description
- Node isolated - All links down.
- Severity
- Major
- Instance
- <None>
- HA Score
- Normal
- Auto Clear Seconds
- N/A
- OID
- vSTPMtp3NodeIsolatedAllLinkDownNotify
Recovery
Monitor the route status at
Verify IP network connectivity exists between the MP
server and the adjacent servers.
Check the event history logs at
for additional SS7 events or alarms from this
MP server.
Verify the adjacent server is not under maintenance.
It is recommended to contact My Oracle Support for assistance if needed
