| Oracle® Communications Diameter Signaling Router Roaming Steering Release 8.3 E93199 |
![]() Previous |
![]() Next |
Disabled buttons are grayed out. Buttons that are irrelevant to the selection or current system state, or which represent unauthorized actions as defined in Group Administration, are disabled. For example, Delete is disabled for users without Global Data Delete permission. Buttons are also disabled if, for example, multiple servers are selected for an action that can only be performed on a single server at a time.Table 2-4 Example Action Buttons
| Action Button | Function |
| Insert | Inserts data into a table. |
| Edit | Edits data within a table. |
| Delete | Deletes data from table. |
| Change | Changes the status of a managed object. |
Some Action buttons take you to another page.
Table 2-5 Submit Buttons
| Submit Button | Function |
| OK | Submits the information to the server, and if successful, returns to the View page for that table. |
| Apply | Submits the information to the server, and if successful, remains on the current page so that you can enter additional data. |
| Cancel | Returns to the View page for the table without submitting any information to the server. |
