| Oracle® Communications Diameter Signaling Router Roaming Steering Release 8.3 E93199 |
![]() Previous |
![]() Next |
Use this task to verify that SoR is activated prior to enabling SoR and performing configuration (provisioning) activities.
Confirm that the SoR folder is visible on the GUI menu. All measurements and KPIs that are associated with the DCA Framework are visible also on the and pages. When activated, SoR becomes visible across DSR (for example, ART and maintenance).
Use this menu to import business logic and provision configuration data.
