Go to primary content
Oracle® Communications Diameter Signaling Router Roaming Steering
Release 8.3
E93199
Contents
Previous
Next
Activating SoR
Use this task to activate SoR.
See
DCA Feature Activation
for detailed information.
Check that the DCA framework has already been activated. See
Add an entry in the
DsrApplication
if it does not already exist.
Add an entry in the
DcaDalId
table if it does not already exist.
Enable visibility for the main menu
DCA Framework
DCA Roaming Steering
subtree.
The SoR instance is added to the GUI menu.
