Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2102 Cmd Rej: Failed reading the IMT table
The IMT table is corrupt or cannot be found by the system.
Recovery
Re-enter the command that generated this error message.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
