Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2101 Cmd Rej: Card location is unequipped
The card location specified by the loc or the rloc parameter must contain a card that is valid for the command and was defined previously in the database for the specified card location.
A card that contains the specified signaling link must be equipped in the specified card location.
For the init-card command, the shelf and card must be equipped.
For the rept-meas command, if the enttype=sctpcard parameter is specified, a card must be installed in the location specified by the loc parameter.
Recovery
  1. Display the cards in the database. Enter the rtrv-card command.
  2. Verify that a card is defined for the specified card location and that the card in the specified location is valid for the command. Refer to the command description in Commands User's Guide for assistance.
  3. Re-enter the command that generated this error message, specifying a valid card location.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
