Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2888 Cmd Rej: MTPDPCQ cannot be less than no. of destinations provisioned
The value specified for the mtpdpcq parameter must be greater than or equal to the number of DPCs provisioned.
Recovery
  1. Display the number of DPCs configured in the database. Enter the rtrv-dstn command.
  2. Re-enter the chg-stpopts command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
