| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The value any for the format portion of the access parameter can be specified only on IXP-based cards. The format value must be set to any on IXP-based cards.
Recovery
Re-enter the ent-bp command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
