Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4161 Cmd Rej: Routing Context is required for SUA
If a routing key is associated with an SUA application server (AS), then the rc parameter must be specified.
Recovery
  1. Display the routing keys and routing context value. Enter the rtrv-appl-rtkey:display=all command.
  2. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and the Database Administration - IP7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
