Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4164 Cmd Rej: G-Flex MAP Layer Routing feature must be ON
The G-Flex MAP Routing (G-Flex MLR) feature must be enabled and turned on before the gflexmaplayerrtg, maplyrrtgon, or maplyrrtgoff parameter can be specified.
Recovery
  1. Display the status of the G-Flex MLR feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable and turn on the G-Flex MLR feature as necessary. Refer to the G-Flex C7 Relay User's Guide for assistance.
  3. Re-enter the chg-gsmopts command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
