| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The loc and stat parameters cannot be specified together in the command.
Recovery
Re-enter the rept-stat-card command that generated this error message specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
