| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
For the inh/unhb-alm commands, if a value of card or dlk is specified for the dev parameter, then the loc parameter must be specified.
For the rept-meas command, if the enttype=sctpcard parameter is specified, then the loc parameter must be specified.
For the rept-stat-card command, if the mode parameter is specified, then the loc parameter must be specified.
For the rept-stat-enum command, if the peakreset parameter is specified, then the loc parameter must be specified.
For the rept-stat-iptps command, if the link parameter is specified, then the loc parameter must be specified.
For the rept-stat-j1 command, if the j1port parameter is specified, then the loc parameter must be specified.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
