Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4336 Cmd Rej: TINP and CNCF cannot be in the same GWS action set
The tinp and cncf gateway screening stop actions cannot be specified in the same action set.
Recovery
Re-enter the chg-gws-actset command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
