Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4334 Cmd Rej: Requires C-linksets parameter tfatcabmlq to be set to 0
The tfatcabmlq=0 parameter must be specified for all C-linksets before the lsrestrict=off parameter can be specified.
Recovery
  1. Display all linksets. Enter the rtrv-ls command.
    C-linksets are identified with a C in the LST field.
  2. Revise the linkset data as necessary. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the chg-ss7opts command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
